Forecast for today. Winds out of the North at 6 kts shifting to the West at 9kts. Perfect day for the Frostbite Regatta on Canyon Lake! Best of 3 races wins the regatta. First race went off without a hitch, I came in second place behind a Sabre 36. We nailed the start of the second race and headed for the windward mark. Everything is looking good and we set the pole for a downwind run to the next mark. As we round the mark we see one of the shrouds from a Catalina 30 launch off the deck. Fully expecting the mast to come down next, I ducked inside of the 30 and was prepared to take evasive action if the rig came down. They got the main down quickly and fired up the engine, we then see the headsail on the Sabre go slack and the boat almost stops. (busted shackle). He drops the headsail and continues the race. Seeing our chance to make up for the second place in race 1 we got all excited seeing the Sabre under main only. Another down wind run and we notice whitecaps on the other side of the lake. Thinking it is a 15kt puff or so, we set the pole and look to put some distance on the fleet. How about a 50kt gust? I have up full main and a 150% genoa heading downwind. Sheared the gooseneck right off so now the main is almost impossible to control and we still have the wisker pole up. Kudos to my crew, they got the pole down in record time and managed to not get knocked overboard. We then spun the boat into the wind, fired up the engine, furled the genoa, dropped the main and headed for the marina. Full throttle into this wind and I was barely making 3 kts with lots of spray coming off the port bow. The boat was heeling 10 degrees with no sails up! When all was said and done, 6 boats had suffered damage. And here I was worried we weren't going to have enough wind for the race as my boat typically does best when the winds are in the mid teens. I just don't see how the forecasters missed it by so much.
s/v Lucky
1984 MK I Hull #266
San Antonio, Texas
Sorry to hear of the damage for you and the others, Bill. At least no one was hurt.
Our next race in the series is today with 15-25 forecast. On a 27' Stilleto catamaran, it should be fun. Can you say 18 kts of boat speed?
That would be fun Duane. I crewed in the Wurstfest Regatta 2 years ago on a Corsair F-28. They are rockets!
s/v Lucky
1984 MK I Hull #266
San Antonio, Texas
Ahhhhh... the joys of lake sailing and sudden unexpected downburts. Did you loose the whole goosneck or did the pin just shear off? I have noticed on some boats there is sometime extra wear on the goosneck. I had this issue until I added an extra washer. It is one of the areas I now check on a regular basis. Still it's no fun having stuff like this happen. Glad everyone was OK.
John Meyer
Hilbre 2135
San Pedro, CA
John Meyer
Hilbre
C36 MKll, Hull 2135
The pin sheared off. Unfortunately, Catalina had to order the part. So for the next 5 weeks Lucky will be a lake house and not a sailboat. The owner of the Saber called me at home and wanted to make sure everything was OK with the boat which was pretty cool. He is a member of a different yacht club and the atmosphere between the 2 clubs has not always been that good.
s/v Lucky
1984 MK I Hull #266
San Antonio, Texas
