rain water in bilge
nics0car
rain water in bilge
I've been extracting about a gallon of rain water from my bilge almost daily during rainy weather.  Wondering where it could be coming from since I re-caulked the shrouds' deck plates and hatches, I figure it must be coming down the mast....??
Correct. And probably other places which I haven't thought about.
NicsOscar;
 Just be sure that it's rain water ! If your boat is in salt water, take a quart and boil it on the stove to see if there is salt in it. Obviously, if there is salt in the pot after the water boils  off, you have a different problem. Just a word of caution. Keep a close eye on the cables running down the mast and at the mast base. Many times rain water will attack and degradate  these cables. Correctly installed  Mast mounted VHF radio antenna installations classically put drip loops in the coaxial cables to prevent excessive amounts of water from traveling down the inside of the co-ax. Good luck in finding your leak.
