Cockpit floor grates for C-36MK I
Sojourn's picture
Sojourn
I have very worn cockpit grates.  The boat is a 1985 C-36 MK I.  I do not want to make my own, if possible, I would rather by the pair.  I can send the existing grates as a template.  Does anyone know of place to get the work done?  I live in SW Michigan and sail on the Great Lakes.
Lou Bruska
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
Pgutierrez's picture
Pgutierrez
Send pictures of what you need to replace...
peter g
2000 C36, MK2, Hull. #1897
Sojourn's picture
Sojourn
The Aft Cockpit grate is about 51" long witha max width of about 20.5",  the ends are damaged and underlying support studs need to be replaced, along with some top cross boards, especially the end boards.  It appears the top cross boards are 3/8" nominal thickness and the underside support studs are 5/8" nominal thickness.  Some modification of the ends needs to be made to avoid breaking either the top boards (which were not properly supported underneath).  The photos are too large to attach, will send you a separate e-mail.
Lou Bruska
Lou Bruska
Sojourn
Eldean Shipyard
