M35B Gear Case Assy.
True Wind
I am currently docked at Hampton Downtown Docks because my cast-aluminum gear case assembly has developed another crack. It had been welded before, but the crack has come back even larger.
I’m sure everyone will have an opinion about repairing cast aluminum, but what I’m really trying to find is a used gear case assembly.
A gear case assembly from any of these Westerbeke/Universal motors should work:
M-25XPB, M-35B, or M-40B
I did take the case by Trans Atlantic Diesel, and there is some hope that the cracks can be temporarily repaired well enough to get us back to our home port.
2003 Catalina 36
Army Sailor
Awhile back I started researching replacements when the seat of my oil filter corroded badly.  I did find one or two on ebay, you might check there.  You can get them new, they are not cheap.  But if yours is cracking, a new one might be the way to go.
True Wind
Westerbeke has stopped supporting that gear case. To add insult to injury, they will not divulge the Kubota part number, which would at least allow me to search for a used one.
2003 Catalina 36
Army Sailor
Looks like the part number might be 16271-0402-0 or 16259-0402-0
not sure what the difference is.
Thats what an online parts search showed me.  Your mileage may vary.
