MkI Forward 5/16" Keel Bolt
Burnt End
I am looking for advice on torquing (or just tightening) the forward 5/16-inch keel bolt on an MkI boat. The vertical clearance beneath the sole prevents the use of a medium-size or larger torque wrench with a deep socket. It does crazy things to the math, but adding one or more universal-joint adapters isn't getting me to a place where I can snug this bolt. Horizontal space around the bolt in the bilge is too limited for crowfoot attachments or extensions to rotate ditto a short-shaft torque wrench. This space, at least on my boat, is all too small for swinging a box-end, open-end, or even a crescent wrench on.
I got it hand-tight from ridiculously loose, but beyond that, there's no joy. My next fallback looks like a hinged breaker bar or a really short one (maybe cut down?), but I am not sure I can get 85 lbs/ft or anywhere near it.
Could you please share the tool configuration or method you used on this specific bolt? I appreciate the help.
J. W. Bell
S/V <currently unnamed>
1985 MkI TR #462 M25
MKE, WI
As ours seems tight I never tried to address this issue, but I'm following. I cannot recall exactly where it's positiioned, but could you use a hole saw to drill into the fiberglass cabin sole above it (if the teak and holly floorboard is removed) to drop a deep socket and extension down onto it, then reinstall the floorboard?  I recall it might be right under the wall for the head, however.
Access to that bolt requires removal of the floor panel in the bow. Once it is removed you will see a small panel over the bolt remove that and you should be able to use the deep socket to turn the nut.
