MKI Owners - Best Upgrades You Couldn't Live Without
KeatLay3's picture
KeatLay3
Hello everyone,
I’m new to the forum and recently purchased a 1986 MKI Cat 36. This summer, I’m planning a trip from Seattle to Alaska aboard the new boat. I’ve been cruising most of my life, but this will be my first time heading north of Vancouver Island (and my first major voyage on this boat), so I’m excited to get her fully dialed in.
We’ve already completed a number of upgrades, with plenty more in the works, and I’d really appreciate hearing about your favorite or most valuable improvements for a trip like this. No suggestion to small!
After owning your boat for years, what are the upgrades you couldn't live without?
Completed so far:
  • New water heater
  • New main galley faucet
  • Macerator pump
  • Dickinson fuel transfer pump for diesel heater
  • LED conversion (currently in progress, thinking of adding dimmers)
  • Deep Cleaning Everything
Upgrades that came with the boat:
  • Newer Propane stove/oven system
  • Electric head
  • New forward water tank
  • Inline Water Filter system
  • Smart Plug with updated AC wiring
  • Newer fridge condenser
Planned upgrades:
  • New batteries (leaning toward AGMs)
  • Electric windlass (would love input here - I've read most of the posts)
  • AIS
  • Navigation software
  • Engine Maintenance with Mechanic (Coming this week!)
  • Replacing Some of the Running Rigging
The project list is long, but I’m looking forward to learning from your experience. Thanks in advance for any suggestions!
— Keaton
Keaton Layman - Platypus III
1986 Catalina C-36 MKI - #521
Home Waters: Seattle + British Columbia
2026 Goal: Seattle to Alaska!
If you have not already done. Replace the raw water pump with Oberdorfer pump and carry a spare impeller.
There has been many write-ups regarding seal replacement and tools needed to replace them.
My last seal replacement I used seals from Granger that I was skeptical that it would last. Todate, I have 22 hours with no leaks. The good thing about them is that you can remove and install them with your bare hands as they are encased in rubber.
Find more content here
https://mei1970.org/saillavie/Oberdorfer_Seals_Replacement
Granger part number 61AA52 for about $15.00 , 2 needed
KeatLay3's picture
KeatLay3
Thanks! The mechanic inspected the boat today and found a small leak in the raw water pump, so I’ll definitely be following your recommendation. Along with replacing the heat exchanger, exhaust elbow, and fuel pump (which is currently broken), plus completing standard maintenance, the engine should be in good shape for another 10 years.
Lanealoha
If you have the M-25 xp as I do on my 88', I would upgrade the mounting bracket to the Alternator if it hasn't been done.  You do not want to have it break, at best its a major inconvenience if you can repair it at sea, at worse you'll kill your engine and need a new one...
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
