Extended Cable length for new depth sounder transducer
When I replaced my Raymarine speed transducer, I soldered and sealed with heat shrink tubing the end of the new cable to the end of the existing cable. I did this rather than snake the new cable back to the pedestal.
I just did the same with a new depth transducer. The electrical conduits on our boat are jamb packed with existing cables and wires very tightly bound together with cable ties. Pulling a new cable thru the boat length with the old one was impossible and I didn't want to remove all the cabinetry and drill new holes to feed it. The Airimar transducer came with a cautionary note to not shorten the cable,  and If more cable length was to be added, use a special water tight junction box, which I could not find on the internet. I suspect shortening the cable might change the impedance designed for the system, but I assume  lengthening the cable by soldering or junction box would not adversely affect the performance.
Has anyone else simply soldered the cables and did it effect depth sounder accuracy?
I would think the accuracy will not be effected, but the display may not respond quickly as expected as the signal might be damaged data. When I replaced mine it came with a plug about 24" from the transducer. Contact Airmar and ask for a male and female pair and install those.
