C36: Downhall and Vang-when do I need both?
UtahGene
Hello:
Not sure if this question should be in this subsection or a sailing section:
My 2007 C36 II came with a downhaul and a Vang. I have sailed the boat on all points and can't see why I should keep the downhall rigged in place, with lines running back to cockpit and complicating my layout of jacklines on the deck. I am thinking of securing the line near the brake at the cockpit and stowing the downhaul under the v-berth. Are there wind situations where the downhaul performs better than the vang?
TIA
Gene
Sombre Del Viento
When I think about down hauls' and cringles, I think about mainsail reefing more than tweaking sail shape. Do you have in-mast furling?  Our vang is an adjustable length rod that Catalina experimented with. Adjusting it to control sail shape is not easy, so we just set the length so it angles the boom up slightly to better facilitate furling in the mast. We cruise and don't race. Even if you don't have an in-mast set up, I would think a vang would give you all the sail shape control you need.
UtahGene
I actually have a vang and a boom brake on my boat. I sort of knew how to use a vang, I did not see purpose of boom brake until sailing downwind in rolly conditions along the northern California coast. I was able to somewhat secure the boom to one side or another with the boom brake rather than using a loose line.
Works well
EUREKA's picture
EUREKA
Hi,
Assuming you have a non furling main, the downhaul/cunningham,  controls the tension on the luff of the sail.
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Home port Barcelona (Spain).
