Water Tank Selector Replacement
richie30's picture
richie30
My three valve selector switches for the freshwater tanks are getting next to impossible to turn, likely they're just old! Has anyone replaced their plumbing and if so, what did you use? Also, is this the best location for them? Because I have a Marine mermaid heat pump, I have to take off the venting to get to the tanks. Not a big deal, but I thought there might be an easier spot, I was thinking of mounting them to the back of the galley large pullout drawer, accessible from the same settee locker.
I'll have to check to see if they would still be below the water tank levels so that the water tank drains by gravity. Thanks for any suggestions or help. Take care, Rich.
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
dpower
It's been a few years but I have seen postings here or in the Main sheet where owners used the area below our stoves or behind the vertical door under the galley sink.  In both cases they had to build the new manifold from PDF parts from HD.
David S. Power
Two If By Sea #1687
Burnt Store Marina
