Exhaust riser
EUREKA's picture
EUREKA
Exhaust riser
Dear all,
Need to replace the exhaust riser on my C36 (1991) Universal M35, actual has 10 years and although is SS (Bought at CD) has developed some rust and the "Y" where the water links the exhaust gases is at its limit.
So, apart from CD ( the price is twice the price paid) is there any other option? I'm looking for something fit & play.
Thanks in advance.
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Home port Barcelona (Spain).
New Exhaust Riser 1-1/4" Black Iron Pipe | Catalina 36/375 International Association
Maybe some help here I built my own for a Catalina 30 years ago with bronze
EUREKA's picture
EUREKA
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
If the rest of the riser is in good shape, except for the water injection pipe, could you detach from the engine and have a new stainless steel pipe welded on?
I also constructed a black pipe riser for my Cat 30 (M25XP engine). It required numerous trips to the hardware store to get the correct pipe lengths and elbow angles, but in the end, was much less expensive than a stainless steel replacement. I suspect it wont last near as long though. I sold the boat a couple years after I replaced the riser, so don't know if any issues developed. The C36 has a ton of room to work in compared to the C30 which resulted in much blood loss and cursing to remove and replace.
