In-Hull Depth Transducer?
Lanealoha
Anyone use this type of system?  If so what do you use and how do you like it?
Dave
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
Sojourn's picture
Sojourn
Hi David,
I have used one since 2013, works just fine.  I mounted it across from the mast on the Stb. side under the lowest drawer in the cabinet.  I am attaching the Brochure.   I couldn't attached the Installation Manual, it was too large for this system.  If you're interested e-mail me and I'll send it directly to you.
Good luck.
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
PDF icon P79 Sonar Brochure.pdf474.49 KB
Sojourn's picture
Sojourn
As a follow up, my depth sounder off set is 4' 4".  We have cruised on the Great Lakes and have put on over 9,500 miles since it was installed.
Lou Bruska
Sojourn
Eldean Shipyard
Lanealoha
Any idea in Salt water?  There info pack says something like boats to 25', I don't see what difference that makes, how does the transducer know how long my boat is?
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
