The hot water on my boat comes out scalding hot.
My water heater is always on when I'm plugged into shore power (unless I hit the press button breaker on the panel to disconnect it.) This means I can only use so many electric heaters to warm the cabin before it trips the outlet breaker.
I am wondering if anyone has used a hydronic heater, powered by the 6 gallon Seaward water heater, to heat the cabin while at the dock. There was a Tech Article on the C34 site about using one while underway, which supplies hot water from the engine coolant/heat exchanger/water heater loop, which outputs a constant temp of 160 from the engine: https://c34.org/wiki/index.php?title=Cabin_Heater
But I'm wondering if I can just use the water heater alone, while plugged into shore power, with the engine off and make more use of the electricity that the water heater is drawing anyway. I've seen the HeaterCraft 500 here: https://innerdemonmotorsports.com/products/500-grill-face-series-heater
My thought would be to hook it to the hot water heater out line, with a return line to the water heater in. I think I would also need to put a recirculating pump on this loop, wired into the same switch the heater would be on, to circulate the hot water. The bonus would be it should also work while underway, since the engine heats the hot water heater anyway.
But I don't know if the Seaward water heater would be able to keep up enough to produce warm, consistent heat while just on electric. Has anyone tried this, just using the water heater to produce cabin heat while plugged in at the dock?
Joe Bousquin, San Francisco Bay
Sausalito Yacht Harbor
SV "Sylbo"
1994 Catalina 36 Mk 1.5, hull number 1337
M35A(C)
That is a good idea to use the existing hot water. But the recirculating pump would take noticeable amount of current and drain the battery quickly. If a water pump can be connected such that the engine belt runs it, that may work.
About Sail La Vie
Thanks, Haro. I would put a switch on it so that the fan on the heater and recirculating pump turn on at the same time. This would only be when plugged in at the dock, or when underway on the motor. On the hook, I use a propane heater. .
SV "Sylbo"
M35A(C)
That would work.
My favorite Anchorage is Richardson Bay. If you see me there on Sail La Vie, stop by and say hi.
About Sail La Vie
