I just wanted to say Hello. I'm a new owner of a 2002 Catalina 36MKII. I'm sure I will be here asking a bunch of questions. Stepping up from a Catalina C30 (which is for sale on CatalinaOwners). My first big question: is there a winter layup document anywhere? I now have AC plus all the standard goodies and will be looking for a list of things that will need done.
Happy to be here!
Thanks Everyone
I have used this checklist every year and have had no problems:
https://www.catalina36.org/members/technical/maintenance/rich-lemieuxs-d...
Ron St. Onge
1995 Catalina 36 MKII Hull 1384
Rich has a very thoughtful list.
I'll add a couple things that may be relevant. If you have an anchor wash down pump I would just disconnect the hoses and let it gravity drain. I say this because antifreeze exposure has crazed/cracked the bowl on my surflow raw water strainer that feeds the pump. It's done this twice and a replacement unit is not cheap. The clear bowls used in all the other filtration areas of our boat have been fine with antifreeze exposure, but not the surflow unit.
If you have AC, I would suggest disconnecting the water inlet/outlet hoses and blowing out the copper coils with air. I use the pump for our inflatable for this and do the same with our water heater rather use antifreeze.
Welcome! We too moved up from a C30.
2005 C36 MKII #2257
Welcome to the forum! You will find a lot of helpful people and posts here. Where you keep the boat and whether she's in water or on the hard can make a difference as well.
Hello. I am a relatively new Catalina 36 owner. She is named Trilogy. She is a Mark 1 with Hull #0053. Her home port is Pass Christian, Mississippi- on the Gulf coast. Thank you to everyone who has posted their hard-learned lessons here for all of us to learn from. If I have some sage advice to pass along, I will.
Skip
Skip Kuzel
S/V Trilogy, Catalina 36, Mark 1
Hull #53
Pass Christian, MS
Welcome to the forum and congrats on your new boat!
JEB
Skip, as most have done, please put your boat/home port info at sign off spot. It is helpful for us to respond with info that may be applicable to your boat. Once you set it up, it loads automatically.
David S. Power
Two If By Sea #1687
Burnt Store Marina
