Engine issues – help
richie30's picture
richie30
We are cruising on our Catalina, 36 mark two along the south coast of Lake Erie. On our way to the thousand islands. Yesterday a mechanic did a little work on the boat at a Marina and told me to run my engine up to 3500 to blow out the carbon more frequently. In gear, I can only get 2500 out of my engine, perhaps the tack is not reading properly.
today when we left the marina, I could only get 1900 RPMs out of the engine, even though that setting took me well up to hull speed, and a bit beyond. It just does not sound normal at the higher rpm. Both fuel filters have been replaced, and before we left, we basically serviced the entire engine system. this included the rebuild of the water muffler system. Any thoughts on what has gone on?
two days ago, we had a log, and I thought perhaps we damaged the prop, the engine also seems to have more vibration. Any help would be greatly appreciated t, thank you, Rich.
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
I don't think the engine can reach 3500rpm. I think the max recommended cruising rpm is 2500 and max rpm is 3000. I used to baby our engine and cruised at 1800, but heard that diesels should be run harder to reduce carbon build up. I now cruise at 2200-2500 rpm. Initially, I saw a bit of increased smoke but after a few times out at the higher speed, I now see virtually no smoke.
If your hitting hull speed at 1900rpm, it sounds like your tac is off, or, if speed is limited by vibration read on...
If your prop hit a log, you should probably check the prop shaft for alignment. Wrapped lobster trap lines and buoys (personal experience with our C30) and logs can certainly knock things out of alignment. The prop may also have been bent by impact. Either these things can increase vibration and change the engine sound.
richie30's picture
richie30
Thanks so much! A diver went down and found netting in the prop! All good now!!
Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
ianw58
Here's a spreadsheet of Diesel Engine Troubleshooting items that was shared with me.
Ian Wilson
S/V Seahorse
Catalina 36', Hull #: 791, Year: 1988, Engine: M-25XP
Tall Rig
Slipped: Marina Village Yacht Harbor, Alameda, CA
File DETG.xlsx13.82 KB
