Removing the Oil Pressure Sensor
Herbert Lape
I'm having trouble removing my oil pressure sensor on my M 35 b. I can't get a wrench on it alone. Should I remove the whole structure attached to the right side of the engine block? Is there a write up with pictures of this project? I have a new one from Catalina Direct to install.
Herb
It requires a deep socket. I removed mine and replaced it. It uses normally open contacts.
