Stern waterline Rest in Water
Bruce Poorman
I probably asked this question years before but have to ask again. My 1989 stern  sits back in the water. The waterline boot stripe is in or  just above the water. Spring cleaning  of the stern waterline is a grueling process to remove the sludge and discoloration. Is this a common occurrence of the 1989 design ? I store very little in the lazarette.
Sojourn's picture
Sojourn
Hi Bruce,
I think the issue is baked in.  The C-36's hull is an older design without a lot of super wide beam aft for buoyancy.  In addition, the prop shaft is angle such that the stern noticeable squats when motoring.  For that reason, I do not have davits on may boat, but rather store the dinghy on the bow and use the windless to raise and lower it.  (An other discussion.)  And lastly, the water conditions of the mooring and sailing waters contribute.  You're on Lake Erie, not regarded as the cleanest or least algae prone.  The more time on the docks vs actually sailing also contribute.  We cruise 6 weeks or more a summer and do much sailing other than cruising.  By the way, I sail on Lake Michigan and other Northern Great Lakes.
My thoughts, hope they helped.
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
Bruce Poorman
Thank you for your prompt feedback regarding the stern in the water. Other than design our boat sits at the mouth of the Rocky River and things do flow downhill ! Also our  sailing was limited to a family illness. You nailed it on all cylinders. Thank you.
GMatthesen
I might add on my 1987 MK l,  I try not to fully fill the stern water tanks. If Im doing a long trip I may have to fill for shower usage, but otherwise avoid unnecessary weight which includes the outboard.
Gary Matthesen
"Holiday"
1987 #50646
Oyster Bay Long Island NY
