I pulled my dipstick and the oil was reading low almost empty. The rest of the stick up to the full mark was spotless no oil.
of course everyone knows you wipe it off and stick it back in to read it and magically it is perfectly full. What the heck this is baffling.
can anyone explain this.
Catalina 36 MK1
1984 Hull #306
Always been that way on ours as well. Maybe air pressure builds up in the tube and prevents an accurate reading at first?
It's a pressure thing, much like holding your finger at the end of a straw and plunging the straw into a glass of water. There is a rubber seal on the dipstick and seals the pressure in the engine. It happens to all of us. Take the dip stick out and let the pressure equalize. Then measure the oil. As a matter of practice, do not measure the oil quantity too soon after running the engine as there is usually a quart stuck up in the engine (oil filter etc) . Diesels engines do not like to be overfilled with lubricating oil. When changing the oil, measure what you take out and only refill that same amount as it is easy to over fill. I check the engine oil levels in the morning before running the engine.
Thanks all this makes sense.
Catalina 36 MK1
1984 Hull #306
