Relocated and improved primary fuel filter for MkI
With a tip of the hat to Les Troyer and Richard Klyce, who wrote up alternative versions of this concept in Mainsheet and gave me the idea:  Just completed the first of this winter's projects, which was to redo the primary fuel filter system on our '85 Mk I (after 10 years of frustration with the original setup).
    The older C36s like ours came with a massive Dahl filter (apparently way oversized for the needs of these engines, according to the two writers above)  located under the port settee, with barely any room under it to drain water or fuel, and a total PITA to service the filter.  Luckily, I never had to do this at sea, but even in port changing this filter it was always made a mess, accompanied by a lot of unpleasant speech.
    Instead, I removed the tilt-out utensil drawer that is to starboard of the galley sink (we could never use it anyway because it was too short for our utensils!) and located the filter there (I reused the door) -- see 1st picture
I put together a system with two Racor 120As as the primary filter, with 10 micron filters, with 3 way valves so we can switch from one to the other if the first gets clogged, without having to shut down the engine.   There's also a vacuum guage plumbed into the common output side, so we can monitor the filter's condition (some time digging through small brass fittings in the parts bins at a good plumbing supply will enable making this a very compact unit, so that there's amble room to access and replace the filters).   The filters and valves are mounted on a piece of starboard, that's attached with angle aluminum stock  --  see 2d picture.
I fabricated a catch basin for the whole system (using a spare fridge door insulation box that I cut down to size) and lined it with an absorbant mat to catch any drips.    See 3d picture.
The Facet pump now pulls from the primary filter (rather than pushes in to it), and is located lower down, reachable through the small door that is below the galler sink (that is used to get to the galley through-hull);  I mounted the pump to a block that I pre-epoxied onto the little angled section of the galley cabinet with captive bolts.  There is sufficient room there to get under the pump to drain it and service the strainer basket.    In truth, the pump could have fit in the same area as the two filters were it not for the fact that I have a vacuum loop for the primary bilge pump line in the left hand (i.e. aft) area of the cabinet that I installed years ago, and I didn't feel like relocting it (maybe some other day).
Sojourn's picture
Sojourn
Nicely done!  Do you have a bill of materials or at least the two valves used?  What is the actual width of the unit?
Lou Bruska
Sojourn
1985 C36 MK1, Hull 495
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
KHughes
Excellent idea. This modification is now on the top of my spring to do list. I'm always struggling when changing that old style filter.If space permits I will also instal a return line after second filter back to the tank to allow for polishing after winter storage.
Cheers
1985 36 M1 # 485
Bronte Outer Harbour
Ont Canada
Per Lou's request:
The measurements of the filter assembly (not including the vacuum gauge) is 9.5" W x 6" H.
I've put together a list of the parts and a sketch of the assembly (sorry for my crappy drawing abilities).
Not included is the starboard, angle aluminum, and various bolts (the lower of the three-way valves is mounted using long bolts as stand-offs).
Sojourn's picture
Sojourn
Thanks for the drawing & BOM.
Lou Bruska
Sojourn
1985 C36 Hull # 495
Lou Bruska
Sojourn
Eldean Shipyard
