Off hand, Does anyone know the wiring size used on the AC side of the Catalina 36 ? 12 or 14 ?
Assuming your unit doesn't pull more than 15 amps, you could use 14 AWG if the length of the run is under 45 ft.
Thanks Ken.
I use the Blue Sea circuit wizard app to calculate correct wire size.
https://apps.apple.com/ca/app/circuit-wizard/id576865083
1985 36 M1 # 485
Bronte Outer Harbour
Ont Canada
Thanks Kevin,
