Catalina 36 hull numbers - where to find?
handymanrjw
Greetings, new Catalina 36 owner. How do I find my hull number?
Typically located on the starboard side, just forward the transom and below the rub rail. It will be hand etched.
Siler Starum's picture
Siler Starum
There is also a second (hidden) hull indentification number marking on the inside under the forward bed on the PS of the hull.
The marking on the outside hull SB-aft is sometimes hard to find / read.
Also on the ID-plate in the cockpit there is the hull number indicated.
Durk Nijdam
S/V "SILER"
Stavoren - Holland
Image icon P1060521 (Large).JPG237.29 KB
Durk;
Thanks for that. As many times as I've been through the boat I never did see that label under the starrboard side of the 'V' berth. Sure enough, mine is there.
