Greetings all,
I just completed the purchase of ENCORE (#1245). I'm in Virginia Beach and will be cruising the Chesapeake as much as I can. Looking forward to interacting with the group and learning more about my new (to me) boat.
Jay
Jay Scharnitzky
"Encore"
Virginia Beach, VA
1993 C36 #1245
Wing, M35
Jay,
Welcome aboard !
The group here has been most helpful and one of the reasons I bought a Catalina 36. There is a great deal of info in the tech section.
I see that you listed that you have an M-35 engine. Is that a standard M-35 or an A or B model ? Sometimes that helps when answering questions.
Hi Bill and thank you for the greating. I'm not sure which it is, I'll look when I go out to the boat again today. Do you know how would I be able to tell the difference?
Jay
Jay Scharnitzky
"Encore"
Virginia Beach, VA
1993 C36 #1245
Wing, M35
Welcome Jay. Are you sure about your hull number / model year? Mine is a 1993 MK1.5, hull number 1238. If yours is hull 1245, your model year should be 1993 or 1994 I would think.
Don Lincoln
"Nancy Lynn"
LaSalle, MI (Lake Erie)
Universal M-35AC
Hi Don, Well it must be like cars then. The original delivery documentation was from OCT 92 and the CG Cert of Doc says year completed 1992, but I have other paperwork that says 1993, and the registration number ends in 93. So I guess the 1993 models were built and released starting in 1992? I know for sure that it is hull #1245.
Jay
Jay Scharnitzky
"Encore"
Virginia Beach, VA
1993 C36 #1245
Wing, M35
Re: the M35 original vs. A or B, after searching for manuals online and downloading the one for the B and looking at my engine, I realized it was NOT a B. I then downloaded another manual that indicated it was for the M35 A. Also did not look like our engine. I finally found a manual with NO A or B designation that is identical to ours, so it seems to me that there might have been a change between the Kubota engine blocks between '91 (no designation) and '92 or '93 that saw the A designation added? Or I'm just confused...a strong possiblity...
Hello Jay, welcome.
I own hull number 1252 and have owned her for 15 years.
Let me know if you need some help.
Bill Matley
Cheboygan, Michigan
Lakes Huron, Michigan,
Canadian North Channel
"Spirit of Aloha" Hull #1252
Thanks Bill!
After doing some work on the raw water side i noticed the engine info plate, it had fallen off and gotten wedged in. It says M35AC. Mystery solved!
Jay Scharnitzky
"Encore"
Virginia Beach, VA
1993 C36 #1245
Wing, M35
