I need to replace the running rigging on by '02 C36MKII. Unfortunately it is in Florida and I am in Colorado. Anyone know the standard diameter and length of the of the genoa and main halyards? Tnx, Todd s/v: Prism
Theme by Zymphonies(link is external)
Here are a few threads I found using the search function that should answer your question (hint: do a query on the term "halyard" in the search tool):
https://www.catalina36.org/forum/technical-discussion/halyard-size-question
https://www.catalina36.org/forum/technical-discussion/main-halyard
https://www.catalina36.org/forum/technical-discussion/halyard-length
On our tall rig, I used 120' of 3/8" -- but our lines run back to the cockpit.
If you download the appropriate manual for your model of C36 from the archives in this site you'll find the sizes of all original equipment, diameter and length of halyards, etc.
Sorry, I can't answer your question, but will say to NOT trust what's listed in the Owners Manual, or at least verify! I replaced my spinnaker halyard with what's listed and wished I had ordered an extra 10 feet of so. I use the spinnaker halyard to move the dinghy from the deck to the water. Unfortunately the figure in the book isn't long enough for that purpose. I also replaced the traveller sheets with what's listed and wished I had gone with a larger diameter line. That then the info on the mainsheet is really off in my book. I have way too much mainsheet.
If you're happy with the lengths and diameters on your boat, I would measure and order based on that. I wish I had done that!
Joe - -
Mobile, AL.
S.V. Makara
1995 Catalina 36 MkII - Hull #1401
I replaced the main and jib halyards last year with 3/8 sta-set X and the 3/8 would not hold in the clutch. Not sure if the clutch is just slipping form age or what but it is a pita. I have to keep the halyard on a winch.
Tim Askew
S/V Allure
1990 Catalina 36 Hull # 1079
Std Rig, Wing Keel, M25XP
3 Blade Auto Prop
Elizabeth City, NC
Free C36 manual online with all sizes. Note others issues with sizes in comments above:
https://www.manualslib.com/manual/1424866/Catalina-36.html?page=18#manual(link is external)
Todd;
The sad truth is that not all yacht braid is created equal, at least in size. Some real good You-Tube videos on the subject. We've shared some of the same experiences as others of not having a new halyard hold in the cluch. I had used the recommended 3/8 and that will most likely slip right on thru an older cluch. You may find that the outside diameter is one size and then compresses to be another because it does not have as much material on the inside. I find that 1/2" from Miami Cordage works the best for me for the main and jib halyard. If you look on Amazon or Ebay you can usually find a good price on it in 150' foot rolls and that will leave you with an extra 20-30 feet to use as a dock or spring line.
The alternative is to buy only 5-10 feet of it and see how it holds in the cluch.
Just my experience.
