Depth Gauge Reading Intermittent/Blinking
I thought I'd read something about this problem in the archive, but I cannot find it now.  The original Garmin GM20 (?) unit we have for wind/depth/air & water temp/speeds is still workiing fine (the 586s fried out after doing an update on a chip, but I'm just using Navionics on the smartphone instead).
What is not ideal is the depth readout which rarely stops flashing and 'gets stuck' at various depths for long periods when cruising in deep water, then works less than ideally in shallow waters with erratic changes between blinking -- but more or less correct.  After our grounding and C-Tow rescue last weekend I thought I'd look into trying to get it working WITHOUT the constant blinking on and off of the readout.  I've tried messing about with the wires coming out of the transducer without any change.  The outer face of it is clean.  The connection to the monitor is fine.  Any suggestions?  Many thanks!
bakerha's picture
bakerha
Kevin:  When we bought our boat I had one that would loose the bottom reading and flash frequently.  Usually when coming into a shallow anchorage - which was the worst time to loose depth for me.  I tried cleaning connectors and eventually trying a new signet transducer with the system I had - no improvement.  So when I updated my electronics that year - new Airmar tilted transducer with my Garmin setup.  Have never had a problem since.
_____________
Harold Baker
S/V Lucky Duck
1989 C-36 mkI TR/WK M25XP
