Needing to re-bleed the engine?
dingodog
Hi all -
I wound up running out of diesel due to a stuck fuel guage (since resolved - there are multiple users on the boat - hard to keep track of who last topped up...).
To bleed the fuel system, I opened the bleed valve on the injector pump, and turned the key to engage the glow plug (and fuel lift pump). I kept it in "glow plug" position for a good 30 seconds or so, though fuel never bubbled out of the bleed valve. I could hear the lift pump chug away the entire time, so knew fuel was in the pump. When I started the engine, it then started immediately and ran fine for a solid hour (I just ran it around my bay to ensure all was well - no hesitation of stuttering at all) - all was seemingly hunky dory.
When I went back the next day however, the engine started up, ran for 10 seconds or so, and then died. Re-bleeding the pump - again no fuel came out of the bleed valve, and again the engine then started immediately and ran fine. My question is... any idea (other than the obvious listserve question of are you sure you're unscrewing the right valve on the injector pump) what's going on? I've now bled it 3x, and during none of those times fuel bubbled out, so I can only guess given the symptoms I'm not completely bleeding it? Again, the engine runs fine immediately after being bled - it just seemingly conks out after sitting for a "rest" period.
Any ideas? Many thanks! Matt
mikeannikki
Sounds to me like you have a small leak, maybe bleader washer?  If you run for an hour with no issues that should be more than enough to purge but if you have a very slight leak it would allow pressure to "relax" and possibly give you problems.  Also have you emptied fuel water separator?  I would dry all connections from pump to engine and look for wet after running.  Look close as it may not be very much.  Previous boat I had leak from bleeder bolt,  I could just tell that it was wet but could have dried all up with half a q-tip or less.  Was not much at all but enough to give me trouble.  Also if you smell diesel without opening bleeder or filter you prob have a slight leak somewhere.    Good luck!
Mike and Nikki Willis
1996 C 36 #1570  "Slip Away"
Fremont, Ohio
Parsons's picture
Parsons
Fuel system problems are a Bit** because the system is in series so any fault in the line kills the whole thing.  Can you specify which engine is in your 1994 boat - M35BC?  Many of the "newer" engines (after late-90's) had automatic bleeders where the primary (low pressure) pump would bypass the injectors and return to the tank.  No bleeding needed, like in a diesel auto.
One diagnosis tool I found useful is a 3-foot length of clear 3/8 inch tubing and an outboard motor fuel bulb - a $20 investment even at West.  Rig the bulb in the middle of the tubing, clamp appropriately, and pump some fuel into a milk jug at various points in the line to see if (1) it runs fuel and (2) there are no bubbles in the suction side.  Test the flow just before the primary filter, and just after.
As Matt noted, an hour of running should have cleared out any remaining air, but it returns (or gets clogged) after sitting. Suggest running your fuel feed tests both before and after resting for a day.
John Parsons
Tall Rig, Fin Keel
Bay City, MI, USA
alfricke's picture
alfricke
You are describing a nasty little problem. It is suspicious to me that when you run the fuel pump you get no fuel coming out of the bleed valve. At least that is how I read what you wrote. I assume that when you do get the engine running, and you then loosen the bleed valve, you do get fuel pouring/squirting out?? If you do, then the problem sounds more like fuel pump issues. On one of my boats, unbeknownst to me, the fuel pump itself had a tiny mesh filter that at one point clogged up and starved the engine of fuel, leading to erratic behavior.
Related to this issue, I am putting a plug in for adding an auxilliary fuel pump with an on off switch right there at the engine. It bipasses the  regular fuel pump when in use. I love it as I can bleed the engine myself, and if the primary pump goes out, I just turn to the auxilliary. It is cheap and easy to do.
Keep us posted
Al
Al Fricke
S/V Jubilee San Francisco Bay
Catalina 36' MkII  #1867
Universal 35-B
I had the exact same problem on my C 30. Turned out to be a very small pin-hole in the primary filter that bled off the pressure after a day at rest. Might also be a bad gasket in the filter. Might want to check that. Have you noticed any fuel in the bilge? That's a sure sign of a leak somewhere.
