I bought a 1985 Catalina 36 MK1. I want to replace the missing spreader boots. Catalina Direct offers a long leather single line boot and a flat rubber boot with two hole in it. They claim they both apply to the Catalina 36 MK1. Which one is it?
Theme by Zymphonies
Toolman;
I think you are better off using the rubber boots as the leather boots can be a bear to lace on and don't ususally last that long in the sun. Plus once the lacing comes loose, the boot must be re-installed. My 2 cents; Get the rubber ones and tape them on.
I'm using the Taylor-made rubber boots from Defender; see:
https://search.defender.com/?expression=spreader%20boots&s=1&Trigger=ac
(Might add your location to the signature)
Bill: Did the large boot fit your spreader arms? I bought some years ago that were a little to small and challenging to install.
This is very timely for me as was just thinking about having to get them ordered. My boat won't go in the water for 1.5 more weeks.
I agree about the rubber over leather - tried them once - they looked neat but didn't last. Thanks
_____________
Harold Baker
S/V Lucky Duck
1989 C-36 mkI TR/WK M25XP
Harold;
I Think they were the medium size (almost sure of it) but you should measure the diameter of your stays and use the link in my previous post to check. The link I sent you out lines the various spreader and wire size;
https://www.defender.com/product3.jsp?path=-1|118|2358491|2358503&id=1004606
Probably too large is better than too small even if you must cut them down to size. If you buy them from a local supplier, you can always return them.Take a look at the spreader and try to estimate the size you'll need. I'll be down at the boat tomorrow and see if I have it in my notes.
Harold;
Checked today and my notes say that I used Taylor-made 'medium' size boots.
I purchased the leather ones from Catalina Direct and installed them last spring. Instalation was straight forward, leather came cut to size with stitching holes punched. So far they have held up very well and we are happy with them.
Jim Donegan
Apparition
1993 Catalina 36 MK 1.5
Hull #1247 M-35A
Milford, CT
I used the large size from west marine and they fit fine. Used tie wraps to secure and then a few wraps of rigging tape to cover the tie wraps.
Tad Davis
Simpler Times
1989 C-36 MK I #1004
Redondo Beach, Calif.
I have the leather spreader-boots from Waterline-Design fitted and this is perfect, easy fit and proper secured with velcro.
Also I ordered initial the Catalina-Direct offered leather spreader boots but these are not of this era anymore - with needle and yarn to fit....
Durk Nijdam
S/V "SILER"
Stavoren - Holland
I have been seeing this new type of boot online and I really like how they look and how easy it seems to install. Are they still holding up? I need to replace mine soon. Thanks.
Tom; Well the spreader boots did not last more than three years down here in the Florida Sun. We replaced the boots with wheels by Harken. These are little wheels that are about two inches in diameter and snap on the stay just above the spreader. The sail falls against the wheel and slides around the spreader. Works a lot better and holds up longer. I just don't know what they are called (anybody ?) but I got them at West Marine. Just wish we could still post pictures but I'll bet that if you went in to WM and explained it to them, they would know what I'm talking about. Try these;
https://www.westmarine.com/buy/harken--chafe-protectors--453415?cm_mmc=PS-_-Google-_-GSC%3ENonB%3EProduct%2520Type-_-453415&product_id=453415&creative=108421553284&device=c&matchtype=&network=g&gclid=EAIaIQobChMI6sfuwYOe6wIVC4-GCh3i-wu5EAQYAiABEgLo8PD_BwE
Thank you for the quick reply. I will try those wheels.
