Hot Water Heater
TippingPoint
Hot Water Heater
Hello,
I just purchased a West Marine Water Heater 6 Gallon,    The PO had a heat exchanger valve where the outlet and inlet (engine coolant) was bridge, the bridge had a value to reduce the pressure and allow more water to flow through to the engine effectively bipassing some flow to the water heater.  This valve was definately not original equipment.    My plan was to not use this valve system and instead have the engine coolant hot go directly to and through the water heater and obviously return to the engine.   However reading the instruction manual of this water heater there is a note in the schematic that says... "Maintain majority flow to Engine Heat exchanger..."   reading this it sounds like I need some kind of control valve that would allow me to bipass some part of the flow of the Main Coolant Retrun.   I have spent many hours researching this but not much discusion to be found.
Anyone out there, I am all ears. (sorry for the long winded explanation)
Ed Dewsnap
Marion, MA
1984 Catalina
Actually, the set-up with the bridge valve apparently WAS original equipment on the Mk1s.   A number of us (me included) have gotten rid of that entire mess, and just run the full flow throught the water heater.   Doesn't seem to cause any problem, and gets rid of a lot of clutter. My understanding (but definitely could be wrong) is that later C36s didn't have it.
See these threads:
https://www.catalina36.org/forum/technical-discussion/cooling-system-bypass-header
and
https://www.catalina36.org/forum/technical-discussion/reason-heat-exchange-bypass-valve
I don't have one on our 2005 C36, but did have one on our 1986 C30 M25. The C30 valve froze in the full open position. I never experienced any water tank or engine underheat with the valve in full open. My conclusion is that the valve is not necessary.
TippingPoint
OK, I feel a lot better now, I am goint to install staight through.   An indeed it was a big mess.
Thanks for the feedback.
Ed Dewsnap
Marion, MA.
Ed Dewsnap
Marion, MA
1984 Catalina
motarded421
Perfect timing on this! I just replaced my water heater with a Kuuma 6 gallon unit. I was under my aft berth poking around and looking for where the engine coolant hoses attach so I could get them off to repace and came across a shady looking gate valve. I assume this is the valve in question. Good to know that I can get rid of it, since it looks like its leaking coolant.
'86 Catalina 36
Work in progress!
