Froli Bed Spring Retrofit - Catalina Direct
ROAM's picture
ROAM
Greg
ROAM
C36 MkII 2001
SF Bay
Yes we have them  under a custom made mattress. We started out many years ago doing the bed quest for better sleeping. Adding different types of foam to the tops of the cushions. Then doing the froli springs. Finally we decided to bite the bullet and do a custom made mattress, That was the best investment. So now we use the from springs under the mattress to keep it up off the fiberglass so it does not sweat.
ROAM's picture
ROAM
Thanks Randy. I'm thinking a custom matress is the route we'll end up going as well. Spend too much time aboard to sacrifice good sleep. Which out here
probably equates to a forced air diesel heater also
Best, Greg
Greg
ROAM
C36 MkII 2001
SF Bay
rjwilson's picture
rjwilson
Randy,
Just wondering where did you get your mattress?  I was informed by the boss we need to look into improving the sleeping area (aka the mattress).
Bob Wilson
S/V Morning Breeze
2003 Catalina 36, Hull 2122
York River Yacht Club
Williamsburg, VA
Parsons's picture
Parsons
I would not mind paying Catalina Direct the extra $40 to support them, over the normal US distributor, Nickle Atlantic:
https://froli-systems.myshopify.com/collections/travel/products/froli-tr...
For those of you that have installed a Froli, how did you handle the cutout / removable part of the v-berth?  Did you cut it open and install a Froli spring underneath, or just ignore the 1.4" difference in height?
John Parsons
Tall Rig, Fin Keel
Bay City, MI, USA
We got our mattress from ​riversidemattressinc.com
As for our cut out I added a piece of 3/4 inch plywood to replace the the cushion then used the from springs.  The mattress we got  is one piece.
mholzmann's picture
mholzmann
I installed the Froli system over my old original cushions and I felt it made a big difference.  I dont regret purchase!!
Mark Holzmann
"Hawkwind"
Sail #1246
