Replace depth transducer
13 posts / 0 new
bdeliman
Is it possible to remove the original depth transducer. The speed transducer comes out easily, but it isn't obvious, to me at least, if the depth transducer can be removed from it's housing. I'm updating the gauges. Has anyone done this, or should I just drill a new a new one.
Bill Deliman
Vivacious 2
Atlantic Highlands, N.J.
William Miller
I just installed a airpath transducer that shoots thru the hull.It will connect to my Garmin 4208 chart plotter.Very easy to install and no hole in hull. It works very good and I still have my old depth finder
William Miller
Bill,
You are correct that the knot meter transducer is sleeved and so you can take the unit out to clean. The depth sounder is not sleeved in most cases and to remove, the boat would be out of the water. You would need to back off the flanged nut, more than likely, use some heat to loosen (make it pliable) any sealant that was involved, and remove. Your choice about whether you drill a new location or use old. I prefer minimum holes in the hull, but must admit I have 2 depth transducers.
bakerha's picture
bakerha
Bill:  I have the same boat as you and replaced my old signet transducer as a first step to getting a more reliable depth sounder.  Mine would loose lock on the bottom at very awkward times so it had to get fixed. My old transducer was under the forward cabin floor and very difficult to access.  I enlarged the hole in the floor to get better access and that helped.  My old transducer was one piece as stated above and not easy to get out.  Heat, a pipe wrench and a lot of swearing seemed to help.  The old transducer was flush mount and the hole was to large for the new mushroom head design. So I had the hole glassed and I re-drilled it to fit.  HOWEVER - the new transducer did not fix my depth problem and in the meantime my chart-plotter also went dead.  Long story but I ended up with a Garmin Chart / sounder and a new tilted element Airmar transducer.  This new equipment works great - rock solid depth regardless of the bottom type. Picture is old transducer with hole cutout larger.
_____________
Harold Baker
S/V Lucky Duck
1989 C-36 mkI TR/WK M25XP
Harold; Exactly where is you depth transducer located? Reason I ask is that mine seems to be located UNDER the holding tank which would mean removing the holding tank to access it. When the time comes, I'm thinking that I would just leave the old one in place and find a new spot for the new depth transducer.
William Miller
I have a 1990 and mine is below the V berth just as you open the center door under the bed. Very easy to get to .Mine was not working as well as I would like so I put in a new one by aiirpath that hooked to my garmin 4208 by nema 2000 and it shoots thru the hull no holes to cut and it is on a different freq than my other one so now I have 2 and the new one works great
William Miller
One othe thing if you go with this unit the dead rise is 20 degrees
Thanks Bill ! That is helpful.
bakerha's picture
bakerha
Bill - my transducer is under the forward cabin sole - see picture.  Pretty easy to get to but the access hole had to be enlarged to get a wrench on it and my hand on the wrench at the same time.  I would be amazed if yours was under the black tank, but, I've seen stranger things on boats. I would be tempted to go the - leave that one alone and install one of the "shoot through the hull" ones like mentioned above.  I am very happy with the Airmar I have and it gives me full sounding (i.e. Fish Finder) capability with my Garmin chartplotter.  Make sure you match the transducer to the dead rise of the hull where you intend to mount it.  Also - on mine there was an arrow that I assumed pointed forward.  But very un-manly like I read the directions before I installed it - and the arrow points toward the keel line of the boat!
_____________
Harold Baker
S/V Lucky Duck
William Miller
I was wrong when I said my transducer is airpath it is the same as Harolds a airmar
glenhelton
For those of you who are using the Airmar shoot-thru-the-hull transducer, do you know which model you have?  And where exactly are you mounting it, right next to the original thru-hull one?
True Wind
Here is my installation of transducers. One is a shoot through. The shoot through is a medium band CHIRP.
David
2003 Catalina 36
