Almost entirely original 2001 Catalina 36 MKii
phoenix
Hi everyone...
I ran across a 2001 Catalina 36 MKii for sale that I am seriously considering. It's being offered by the original owner who told me all about it. This is the short rig with in-mast furling. I don't know which keel. The owner seems to be a very nice and honest older gentleman who, and I say this without disrespect, does not really seem to know much about boats or sailing.
What's interesting is that the boat is almost entirely original. Original standing rigging, life lines and steering cables.  Original instruments including an auto-pilot. Original galley. Original sails.
The cushions, batteries and water heater have been replaced. There are no cushions for the aft sleeping birth. The running rigging was replaced 5 years ago. That’s it.
The engine started tight up, sounded good. It has 850 hours. He says he has serviced annually by a local company I am familiar with, and they would have records.
The wind transducer is damaged and does not work. I was unable to inspect the speed/log and depth transducers because I could not get the bottom drawer below the vee birth out. On the other boat these transducers were in that spot so I assume they are there on this one as well.
The owner reports that when he unfurls the main, it gets most of the way and then puts up a fight. I’m thinking that the sail is blown out and the belly is very deep, making that part of the sail hang up in the mast. Does that make sense? The head sail is a 135% that does not see to have that UV cover when roller furled.
The dodger and biminy show some age and there is a crack in the plastic window on the dodger.
The boat shows signs of age although not really neglect. The cabin light fixtures have some corrosion. There is a crack in one of the doors to the head. The keel bolts have a few spots of rust but nothing serious and the turnbuckle that connects the mast to the underside of the deck looks good. The bilge is fairly wet, with a good 4 or more inches of water. There is a slight odor which I think is caused by the toilet being flushed with sea water (it’s not plumbed to the fresh water tank).
The worst is damage where the chainplate leaked and the wood wall between the salon and the head (this is the wall that the main table mounts to) has some of its veneer separating on the port most edge. There is another piece of wood further to the left that also has this happening. I’m wondering if the channels through the deck that the chain plates pass through are isolated from the deck core? If so there is probably not a wet core issue and I could not detect a soft spot by pressing with my foot.
Another concern is that for the past 10+ years he has not covered it in the winter, so it has been snowed on. He didn't seem to understand that water can seep under things and then freeze (and I didn't have the heart to tell him). I checked the deck hardware and for the most part it seemed well bedded, but the bedding may well be original as well.
If I’m right that there is no core damage, it seems I would want to get cushions for the aft birth, replumb the toilet to fresh water, replace the damaged walls and probably upgrade the electronics. I would also replace the interior light fixtures and convert it all to LED bulbs. I have some pics of the damage if that helps. What might be a fair price for a boat like this, roughly? The owner seems like a nice older gentleman and I don’t want either of us to be taken advantage of. Any comments are appreciated, thank you!
Wally-1840
I have a 2000 and it doesn't look like what you describe with that '01. Granted, I'm in fresh water, but to me  the condition of that boat sounds rough. There's going to be a lot of work and money involved in getting it back to good shape.
My wife and I take great pride in keeping our boat in top condition and if I may say so, it shows. Our slip neighbor is another 2000, always in fresh water, and  it's shows shabby. The owners are as you described to that '01, as they don't really know much. The boat shows that!
If you want to take it on, my suggestion would be try to locate a good surveyor, (tough to find a good one), and go from there.
best of luck.
Wally
"Onanne"
​Lake Champlain
Solla Sollew
First off, I’m not going to answer the question about what it’s worth.  To some extent, “going rates” are regional so I suggest you look at some local boating or sailing rags or websites like Yachtworld.com to get a sense of what sellers are asking these days.  Assuming only ordinary wear and tear, offer ten or better, twenty percent less than the asking price.  Others may have a different rule of thumb.
It may sound like I’m beating you up a bit but your comment “I didn't have the heart to tell him” concerns me.  Do not worry about insulting the seller’s feelings.  It’s your hard earned money and he probably wants to unload his headache fast as he can…on anyone.
Based on the description, I suspect the boat hasn’t gotten much use - or maintenance/upgrades.  You say most equipment is original so assuming no major defects, which a reputable survey should find, if you buy it and assuming you hold onto it for a while, just get use to the idea that a certain amount of replacing/upgrading comes with ownership.  New lifelines (whatever) this year, new running rigging next year, a new nav display, holding tank, or sail (whatever’s most urgent) the next, and so on…and on.  Good luck.
Marc & Susan Garcia
"Solla Sollew" #1473, Mk.II
 San Buenaventura, Ca.
Online
Phoenix,
I have the original wind vane instrument that is mounted on the top of the mast. I removed it because it would not turn. It turned out that it only needed external lubrication. I purchased a new one - it really was not needed. If you would like to purchase mine I will offer it to you for $ 50.00 plus freight.
My display is ST60
Let me know
phoenix
Thank you very much.  If I buy the boat I'll take you up on that.  If I don;t I'll ask the owner if he would like it.
phoenix
Well I don't know if this boat is in bad shape. Other than the obvious leak that the owner pointed out (but could never be missed) there was no other evidence of leaks, from the chain plates or hatches or portlights. The nonskid looked new and no hint of a soft spot on the deck. I realize a survey would find all the flaws, but that's a $1,200 cost. I don't want to pay that unless I have figured out all I can first.
