EV-100 wire guage?
jhenderson
EV-100 wire guage?
MKI. I need to run power to the ACU on my new auto pilot. From the panel to the ACU, mounted on the aft settee, is about 9ft.
Anyone else install the EV-100?
Thanks.
Hummina
1987 Catalina 36 MKI
#741
Bayfield, WI. Usually.
True Wind
Online
[quote=jhenderson]MKI. I need to run power to the ACU on my new auto pilot. From the panel to the ACU, mounted on the aft settee, is about 9ft.
Thanks.
 [/quote]
Which ACU 100, 200, 300,400?
David
2003 Catalina 36
jhenderson
ACU-100. Thanks.
Hummina
#741
True Wind
Online
Let me show you or anybody else that's interested, how to calculate wire size. I just took the ABYC marine electrical re-certification test on Friday. I had to calculate a few of these questions on the test.
Attached is a file that contains the specs on the Raymarine ACU's and the ABYC table for calculating a 3% voltage drop which I recommend for your autopilot. To calculate wire size from the table you need two numbers. One is wire length and the other is current draw. Looking at the ACU 100 spec, it says maximum current is 7 amps. You said it's about 9ft from the distribution panel to the ACU 100. Wire length is the length to the device and back. So you double the 9ft and you now know the wire length is 18ft. The table starts at 10ft and goes up 5ft intervals each time until it reaches 30 and then goes up by tens. What you do if the length falls in between a set of numbers is round up. So we round up 18ft to 20ft. Same with the current. If the current falls between two numbers, you round up. So in your case we round up the current to 10amps. If you look at the intersection of 20ft and 10amps in the table, you see you would need a 10ga wire. Don't forget to fuse the wire.
David
2003 Catalina 36
jhenderson
Wow.
Best. Answer. Ever.
Thank you so much, that is above and beyond. I will be printing that out and keeping it with my manuals!
Hummina
#741
Blue Sea has a handy app that allows you to plug in the values and come out with the correct wire size.
called "Circuit Wizard"
Les
Gsmith's picture
Gsmith
You may want to check the connection point on the ACU to see if a number 10 wire will comfortably fit, it didn't for me a couple years ago so ended up moving the controller closer to the panel.
Gary Smith
93 MK I, Hull #1231
Std rig; wing keel
M35A Oberdorfer conversion
