Windlass wired remote
I have been successfull in installing a remote windlass wired control box that I can carry with me to raise and lower the anchor.
You can find more content and photos  HERE    including Maxwell Windlass PDF manuals that you can download.
Click on image below to play the video.
knotdoneyet
Very cool.  Where's the cable for your remote connected?
Looks like the PO of my boat had all the parts but never installed it.  I have the box and a remote switch that I would likely put at the helm and add the second foot switch at the anchor box.
2000 C36 MKII 1825
I used 2 gulf cart relays - 85 AMP contacts, 12 VDC coil, to turn on the motor. The relays are located in the V-birth close to the windlass motor, behind the panel using 00 AGW cables connected to the motor. I ran a cable from there to the storage under the starboard seat. There I have a 4-pin plug. I used 24 AGW  4 conductor microphone wire ( they are very flexible and have a soft jacket) with 4-pin plug and at the other end is a 2-way switch - that you see used to rotate the windlass both direction. This is a wired remote - there are no batteries used. When I am at the helm I use the switch to lower the anchor while I am backing up. The motor stops as soon as I release the switch.
My understanding is that the remote units available - the motor des not stop immediately after the button is pressed.
 I will post images of the control relays next week on this post. I have previously posted those images of the control relays.
Search for windlass control relays - you find the post.
Were you able to view the video?
I have up/down foot switches, so I just ran wires from them back to a cockpit terminal and made a remote from a high current 3-way momentary switch.  I only use the remote when I am single-handing and can't leave the cockpit...
jhenderson
The PO installed one left of the wheel, so kids, dogs, and adults can hit it when I least expect it!
Hummina
1987 Catalina 36 MKI
#741
Bayfield, WI. Usually.
