I know I should be reading a good book, but if I do want to watch TV via internet, is this possible?
Trac Vision seems pretty expensive. Wish I could get a small dish!
Any thoughts?
Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
I can't see one on my boat -- but I would think if you search for cable cutting - you would find lots of ways folks have been watching TV over the internet without fancy gear. Getting fast/reliable internet to you boat is another story -- There is also still TV the old way -- broadcast.
Les
We have Dish Sat at home and bought a tailgater anteena that sits on the bow of the boat and stow it down below when under way.It only works at dock not under way or at anchor but at 350$ it doesnt cost much and works great
We have a cheap HD antenna, about $30. It works whenever a station is in range. They advertise up to 50 miles, but 15-20 is probably more like it. We sail on the Upper Chesapeake and have found we can get at least one local station, sometimes 3 or 4. Using our cell phone as a mobile hot spot also sometimes works, but not reliably and watching a movie eats up a lot of data which can get expensive
Keith Moomaw
Almond Joy #138
I have T-Mobile and a Visio smart TV. Can stream Prime, HBO and others without Burning my minutes. I can use the hotspot or just plug in my iPhone to the tv with an HDMI adapter. This ended my futile quest for WIFI.
I was going to spend hundreds of dollars for a WIFI setup and just needed the right mobile carrier.
Times have changed!
2000 C36 MKII 1825
Good to know about T-mobile. We used 4g's of data to watch one movie, that pretty much wiped out our data for that month with Verizon. The movie would stop to buffer perhaps due to a slow connection speed. Any problems with that?
Keith Moomaw
Almond Joy #138
[quote=cappy]Good to know about T-mobile. We used 4g's of data to watch one movie, that pretty much wiped out our data for that month with Verizon. The movie would stop to buffer perhaps due to a slow connection speed. Any problems with that?
Keith Moomaw
Almond Joy #138[/quote]
No problem with T-Mobile as streaming music, Netflix, Prime, HBO and the other services I use don't count against my data plan, so I don't get throttled. I have found my cellular data to be faster and more reliable than WIFI.
I just got two more free lines of 6gb (had to buy the SIM card for $20). Gave one to my mom for her iPad and looking for an amplified antenna for the boat to keep a 6gb hotspot permanently on the boat.
2000 C36 MKII 1825
Connectivity and streaming varies with all wireless media. It's an it depends on where you are and what the coverage is.
Disney in Orlando, the coverage is horrible. Yet I did a FaceTime 7 miles offshore heading to the Key West off Ft. Myers. I have found WIFI to be less reliable. Satellite has its issues also.
2000 C36 MKII 1825
We have an IPhone with unlimited internet/wifi so we use an apple plug and mirror it on the screen using Netflix. As long as we have a signal it works great. Sometimes it stalls a bit streaming but usually great...
Rob & Lisa Mouatt
Catalina 36-JOURNEY
"Sail away, Sail away, Sail away!"
Enya-
We placed a 24 inch Vizio smart tv above the card table. We have unlimited data on our android smart phones, so we installed a free hot spot app called foxfi, and we use our phones to broadcast to the Netflix, Amazon, etc., apps that come preinstalled on our smart t.v. If reception is bad, we sometimes hook our phone up directly to the TV via a micro HDMI cable, which mimimizes data speed loss between devices. And if there is no data signal whatsover, Amazon recently started allowing it's members to download movies and TV shows to their SD cards on their phones...works great. We also bought a 50 mile indoor antenna that pulls in a bunch of channels here in Long Beach, many of them are broadcast in HD. We usually hoist the antenna about 6 or 7 feet up the halyard for better reception. Finally, we bought the VIZIO E-Series E241i-A1. One cool aspect of this smart tv is the stand. It is triangular and juts out just below the bookshelf cross beam above the card table, thus holding the TV in place without having to mount it. I simply tied a string around the base and the crossbeam, just to be sure.
Hope this helps--Joel S.
Joel Schwartz
s/v Get-A-Grip
1993 Catalina 36 Hull #1259
Newport Beach, California
