Schaefer Furler
Hynnimac
Schaefer Furler
My manual shows 3 models, 1100, 2100, and 3100.  Which one was factory installation on the 2001 C36 MKII?
Mine is a 2002 and it has a 2100. There should be a big label on the roller device telling you which one it is, or you may have a brochure in your owner's manual / paper collection giving that info.
Hynnimac
Thanks.  My manual (paper work) covers all three models.  The label on the Furler has become unreadable.  I want to replace my furling line which I measured to be about 90ft.  This is the length on the 3100 according to the manual.  The 2100 lists a length of 70ft in the manual so I was a little confused as to which furler I really had on the boat.
knotdoneyet
More is never bad with lines.  If it's too long once you install it, then cut it.  20' of spare line could come in quite handy.  But you can't add line to a line that's too short.  Then you could end up with a 70' spare line.
just saying.
2000 C36 MKII 1825
