Rudder replacement
nauti-gal
Rudder replacement
Message:
Recently hit a under water obstruction resulting in damage to the rudder.
Nauti - Gal is a 36' Catalina MK11 2001' hull 2026.
Need to replace rubber but need advise as to why the rubber is 46"; whereas the wing keel is a approximately 28" to 30". Therefore, can anyone explain why the rubber needs to be 16" longer than the keel.
Incidentally, no damage to the keel as only the bottom of the rudder made contact with the obstruction.
Any advice will be much appreciated.
Jim
VermontSailor's picture
VermontSailor
I have recently replaced the rudder on our Wing Keel, 1999, Catalina 36. The rudder is 46 inches, which is slightly less deep than the wing keel. The rudder was fabricated by Foss Foam.
Nile Schneider
Mañana C36 #1798
Lake Champlain, VT
paulrenecyr's picture
paulrenecyr
I have heard that the same length rudder was used on both the fin keel and the wing keel models.  So on the wing keel models the rudder is more susceptible to getting damaged.  Do not know if this was always the case but it seems like a bad design choice.
Paul Cyr
C36  "At Last"
1984 hull# 369
Oriental, NC
VermontSailor
The wing keel rudder is shorter than the fin keel rudder.  If your rudder is deeper than your wing keel then someone had previously replaced the original rudder with the wrong one.  I recommend contacting Foss Foam in Florida, they can make either rudder for you and they are less expensive than Catalina Direct.
Nile Schneider
Mañana C36 #1798
Lake Champlain, VT
I've seen a lot of rudders on shallow draft keel boats (at our self-help club I work the haul out and launch crew every year) and most (all?) have shorter rudders than the depth of the keel for obvious reasons (I. E. Your issue). The difference is that they match the volume of surface area of a deep narrow rudder with a shorter but much longer rudder. To control the steerage it is all about the amount of surface area that is in contact with the water behind the keel.
