Battery Monitoring System
Rockman's picture
Rockman
I thought having some additional information on the battery status seemed like a good idea.
So I installed a battery monitor. It works well, and was fairly easy to install.
Would I do it again - yes.
ludo's picture
ludo
Nice! Looking to do the same but in using something NMEA compatible or even better signalk :) Actually any advise from anyone on sensors compatible NMEA we should use?
Ludovic François
Marina Del Rey, CA
Nice installation, good choice.
You should read these, too:
For everyone installing a battery monitor:  The "Gotcha Algorithm" thread, a "MUST READ"
http://c34.org/bbs/index.php/topic,4922.0.html
DEFAULTS are factory settings that are made to be modified to suit your setup.
Also read this one:
Programming a Battery Monitor (by Maine Sail)
http://www.pbase.com/mainecruising/programming_a_battery_monitor
