Trying to use list serv
Talisman
I'm trying to send out an email on the listserv and it doesn't seem to work.  I'm not getting it back as an email which I assume I would.  What is the email address I should use to send it to?  Am I properly registered to use it?
Enrique Rodriguez erodriguez7@aol.com
Talisman
Enrique
Talisman
1998 36 MK2 Hull #1673
Tall Rig Wing Keel
M35BC engine
Old Saybrook, CT Summer
South Glastonbury, CT Winter
Channel Islander's picture
Channel Islander
Many email providers do not show you the messages that you send to a list. This includes Gmail and AOL and probably others. It's nothing to do with our list, and unfortunately we can't change it.
However, you can go into your subscription preferences via the URL contained in the footer of every message sent to the list, and check the Receive acknowledgement mail when you send mail to the list? setting box. This will cause the list to send a separate message to you confirming that your list message was received.
[ Note that the setting Receive your own posts to the list? will have no effect if your email provider doesn't fetch a copy of a message you send. ]
Nick Tonkin
Talisman
As a member of the list I guess I was used to receiving the emails like everybody else regardless of if I was the originator or not until this email.  I sent one out after it and did receive it back.  I'm not the type that requires confirmation.  I just thought since I was use to receiving it and didn't my email had not gone through
Enrique
Talisman
Tall Rig Wing Keel
M35BC engine
