Mast & spreader manufacturer for Mk I
Ciscocat's picture
Ciscocat
hi all I i am shipping my boat to seabrook texas and while up taking a look at the rig after it had been wrapped I noticed that the spreaders were not co located with the mast.  No one was around to asking so I don' t know if the spread were misplaced or if someone walked off with then.  The reason for the post is to find out if anyone was the specifics of the spread length, cross section etc or the manufacter.  I have been able locate that information in the online doc, not say'n it is not there but I couldn't find it.  Any info would be appreciated
regards
!ike
Mike Hogan
s/v Ciscocat #226
Mark I XP25, std rig
EUREKA's picture
EUREKA
Hi Mike,
I bought last year mines at Catalina direct. If any doubt, I'm sure they will be able to help you.
Regards.
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Home port Barcelona (Spain).
Ciscocat's picture
Ciscocat
I thought of them and they do try to help but to be honest most of there information and products are related the the Mark II, The spreaders on my boat have a base that is concave and the drawings for the mark 2 show the base as flat and i believe that they have some type of fitting that attaches to the base that conforms to the curvature of the mast.  the problem is that the spreaders i have appears to be somewhat wider apart than the newer spreaders.  Rigright can fabricate the spreaders but I need the actual dimensions, which i don't have since i don't have the spreaders, thus the question..  but thanks for the suggestions.
Mike Hogan
s/v Ciscocat #226
Don't know if Elasio means directly from Catalina Yachts or from Catalina Direct... they're two different organizations. You might want to try Catalina Yachts though they have not been as helpful since they moved all their files to Florida if you've already tried Catalina Direct.
