Catalina 36 #572
In order to get to the exhaust riser which I think is leaking, I need to remove the shelf in the aft cabin.
There must be a trick to this because I can't even figure out where the screws are on the port side. The 3 just inside the door frame on the starboard side are easy enough but the port side screw(s) are invisible.
Will someone please enlighten me. Where and how many ?
Philip Schofield
Ventura Yacht Club, CA.
Tommy T
Hull 572
Philip,
The shelf in the aft cabin is held in place with several screws from the INSIDE of the shelf. I've attached a picture showing the cleats on the port bulkhead to which the shelf is attached. The screws are hard to reach, but not impossible. I was able to get them from underneath, reaching up near the aqualift muffler. From memory, there are also several screws on the starboard side from the inside. FWIW, when I re-installed the shelf, I used screws from the outside rather than the inside. You can hardly see them, and it is MUCH easier to take the shelf off a second time. Hope this helps.
Philip Schofield
Tommy T
Hull 572
