Fresh Water potable after long periods??
10 posts / 0 new
andreshs1's picture
andreshs1
Hi all
First of all, excuse the newbie question to follow...
Recently the admiral decided not to bring fresh drinking water to the boat anymore. Not a big issue for me as I happily survive on beer, but not the case for the kids....
so my question is: how do you treat the water in the tanks to ensure that it is good for drinking???
I have bought a filter, but I guess thst I am looking for a proven method..
chlorine?
bleach?
magic pills??
Thanks & Regards
Andres
Andres & Arantzazu
S/V "Carpe Diem"
Hull: 1773
1999 C36 mkII
Hong Kong
http://www.abclubhk.com/
knotdoneyet
From the manual, it works great.
INSTRUCTIONS FOR SANITIZING POTABLE WATER SYSTEMS:
TO ASSURE COMPLETE SANITATION OF YOUR POTABLE WATER SYSTEM IT IS RECOMMENDED THAT THE FOLLOWING PROCEDURES BE USED. THIS AT- PLIES IF IT IS A NEW SYSTEM, ONE NOT USED FOR A PERIOD OF TIME, OR ONE THAT MAY HAVE BECOME CONTAMINATED.
(1) PREPARE A CHLORINE SOLUTION USING ONE GALLON OF WATER AND CUP OF CHLORX OR PUREX HOUSEHOLD BLEACH ( 5 % HYPERCHLORITE SO- LUTION). WITH TANK EMPTY, POUR CHLORINE SOLUTION INTO TANK. USE
ONE GALLON OF SOLUTION FOR EACH 13 GALLONS TANK CAPACITY.
(2) COMPLETE FILLING TANK WITH FRESH WATER. OPEN FAUCET AND DRAIN COCK UNTIL ALL AIR HAS BEEN RELEASED AND ENTIRE SYSTEM IS FILLED.
(3) ALLOW TO STAND FOR THREE HOURS.
(4) DRAIN AND FLUSH WITH POTABLE FRESH WATER. (IMPORTANT)
( 5 ) TO REMOVE EXESSIVE CHLORINE TASTE OR ODOR WHICH MIGHT RE- MAIN, PREPARE A SOLUTION OF ONE QUART VINEGAR TO FIVE GALLONS WATER AND ALLOW THIS SOLUTION TO AGITATE IN TANK FOR SEVERAL DAYS BY VESSEL MOTION.
(6) DRAIN TANK AND AGAIN FLUSH WITH POTABLE WATER. (IMPORTANT)
THE ABOVE RECOMMENDATIONS CONFORM TO SECTION 10.8 IN THE A119.2 CODE COVERING ELECTRICAL, PLUMBING, AND HEATING OF A RECREATIONAL VEHICLE. THE SOLUTION IS APPROVED AND RECOM- MENDED BY COMPETENT HEALTH OFFICIALS.
2000 C36 MKII 1825
andreshs1's picture
andreshs1
Hi
how often would you do this?
Regards
Andres
Andres & Arantzazu
S/V "Carpe Diem"
Hull: 1773
1999 C36 mkII
Hong Kong
knotdoneyet
I do it before long trips and then only if it gets stale smelling.  You can add a capful of bleach to keep it fresh when you fill up.  Note that we don't drink the water in the tanks and just use it for showers, cleaning ...
2000 C36 MKII 1825
That is the approved method for cleansing the tanks and I usually do that in the spring before launch but to be honest, for drinking we always bring bottled water and use the tanks for washing dishes and the shower. When we're cruising we refill the gal. jugs from dockside water so its always pretty fresh.Check out the filter screen going into your water pump after a few weeks and I think you'll see why, even with all the purging (which does take a while with all the filling, sitting and draining). Try cleaning out the screens on the end of your faucets too and I think you'll be surprised about the junk that's is in the water.
There is also some thought that bleach, even is small quantities, is not the best for the parts in the pump and plumbing.
andreshs1's picture
andreshs1
Hi there
Thanks for the info I will take this into consideration and run it by the Admiral.
I did check the filter a few weeks ago and I must say that it was pretty clean and I have had the boat for one and a half years already and never clean it before. That being said, it is worth mentioning that in Hong Kong it is safe to drink tab water. And to add to the safety I was going to install another filter for potable water.
Thanks for the advise!
Regards
Andres
Andres & Arantzazu
S/V "Carpe Diem"
Hull: 1773
1999 C36 mkII
Hong Kong
Andres,
After doing a "shock" treatment each spring, and flushing each tank a few times, I add one capful of bleach to each tank when filling, and the water is fine for the whole season.  I do not have a filter, and I drink the water from the tank all the time.  It doesn't taste quite as good as "fresh mountain spring water", but it's not bad at all.  I guess I have less discriminating taste buds.
knotdoneyet
I was considering keeping a zero-water container in the fridge and just fill it with water from the tanks.  Seems like it would be the easiest fix and cut down on water bottles.
2000 C36 MKII 1825
dpower
We have a full system filter on our boat and a cap of bleach whenever we fill a tank.  Our water tastes great even after sitting through the summer.
David S. Power
Two If By Sea #1687
Burnt Store Marina
FlyMeAway
Add me to the list of folks who don't drink the water out of the tanks -- I buy cases of bottled water at Costco or the grocery store (usually $4 or less for 24-36 of them, depending on brand). I do hate the plastic waste but I make sure to recycle 100% of them (this is an ironclad shipboard rule -- if a port doesn't have recycling, I store them until I find one that does).
When we are just going out for a day sail, I have a couple of Nalgene bottles that I fill at home and put in the fridge.
I have long considered getting a 3M system; for cold water only at the galley sink tap I think it would be easy to install under the sink or nearby. They cost less than $150 and the filters aren't that expensive either. Not sure if you can get them easily in HKG but plenty of people will ship to you there.
David
s/v Portmanteau
Hull #2133 -- 2003 MKII
Seattle, WA
