Am a new owner of 2005 C-36 MkII....when using macerator pump to pump overboard, how do I know when the holding tank is empty so as not to damage macerator pump impeller by running dry? Thanx.
Dave & Nancy Warren
"Blue Heron"
Norwalk Cove Marina, CT
2005 C-36 Mk II #2256
'Anniversary Edition'
Wing M35B
Not only would you be able to see a difference, you will hear a difference in the sound of the pump.
David S. Power
Two If By Sea #1687
Burnt Store Marina
David - by "hearing the difference" do you mean the macerator pump will go to a higher pitch 'whine'? And not sure how I will "see the difference". Thanx for clarifying
Dave & Nancy Warren
"Blue Heron"
Wing M35B
Yes, the pump will speed up and the whine will have a higher pitch. As the holding tank is emptied, from the cockpit you should be able to see the discoloration of the effluent.
David S. Power
Two If By Sea #1687
Burnt Store Marina
Thanx again for the info, David
Dave & Nancy Warren
"Blue Heron"
Wing M35B
