Annoying noise from inside the mast
10 posts / 0 new
mikeandaeh
How to get rid of the very annoying noise coming from inside the mast. I'm fairly certain it's a cable from the electrical instruments that the previous owner replaced. I tinkered with the halyards and convinced myself it's not coming from one of them. At anchor or in the marina, with sails down, it's creates a very loud and rhythmic (as the boat is rocking) banging noise. It's very annoying when we are trying to sleep. This is our first sailboat so I still have a lot to learn. Is this normal? Is there a simple way to eliminate it?
Mike and Apidee
Ocean Marina, Jomtien, Thailand
C36, MK I, Hull #568 "Amore"
If it's a soft 'bump', it's probably the haylards. I've found that pulling them tight helps with that. If it's a sharper sound, like a click, then probably a wire. Don't know what vintage boat you have, but mine has a plastic tube inside the mast that all wires run through. That prevents both noise and abrasion. If a wire was run outside of the chase (tube), then it could indeed get noisy; my first boat (Watkins 27) had lose wires inside the mast and they would bang around a bit.
greigwill
I had this problem when some rivets holding the pvc pipe inside the mast failed and it would bang around in a rolly anchorage... i fixed it by taking off the bolt that holds the small underdeck turnbuckle to the mast..then putting a straw taped to the nozzle of a tube of 5200,put the straw thru the bolt hole and squirting it around the pvc tube on the far side of the mast..it worked and locked down the pvc tube..
Gibsons Harbour BC
www.landsendbc.ca
Mike,
I must admit that I have bad news: there IS no EASY solution.
You have eliminated the halyards. I think you're right, because most of us have learned to tie our halyard off the mast well outside the mast and keep them tensioned.
The ONLY thing left are wires.
When we bought our boat in 1998, there was a horrible "mast slap" when we were down below. Our PO had done everything right as far as we were concerned, and he'd owned the boat since new in '86.
We anchor out a LOT and lived with it ONLY because we planned to redo the standing rigging in a few years. I hated it. The Admiral hated it. We ALL HATED it. It su*ks. I hear ya!:):):)
Once we pulled the stick, we found that the OEM installation managed to be so "stupid" that they'd run one of the many OEM wires OUTSIDE the conduit that's inside the mast. You know, the one that's MADE to run wires inside it!
Once repaired, the noises disappeared.
I can find no way, other than pulling the mast, to know for sure what's going on inside.
Sorry for the reality check.
Good luck.
PS - You might try to find some noise deadening wrapping material around the mast down below in the interim period. I figure you have a keel stepped mast.
greigwill
Yes you can see whats going on inside the mast...remove the two bolts that hold the small below deck turnbuckle onto the mast ..Put a penlight or better yet,one of those small led lights at the end of a flexible wire on the top hole while peering thru the lower hole..Do this at anchor or when the boat rolls and you will see whats moving..I have done this..the banging will drive you nuts if you dont!
Gibsons Harbour BC
www.landsendbc.ca
mikeandaeh
Thanks for the feedback and great suggestions. I'll take a closer look and see if I can find out what's going on inside. I didn't realize there was a tube inside the mast for the cables. I guess there is some consolation knowing I'm not the only one that has experienced this problem. We are hauling her out next week for anti-fouling and I think fixing this problem has just moved to the top of the list of additional repairs I had planned. Whatever it takes, it has to corrected! Thanks again.
Mike and Apidee
William Miller
Greg
I take it the bolts are threaded into the mast.
greigwill
Yes Bill,the 2 bolts are threaded into the mast ..they fasten the eye for the mast t-buckle
Gibsons Harbour BC
www.landsendbc.ca
William Miller
Thanks Good winter project
Breezly
I recently had the standing rigging replaced (last month) and now have this very annoying twanging and banging coming from inside the mast. I'm not sure if it's a result of the work or when I was out at anchor a week or so ago and it was exceptionally rolly. I think the latter.
When I put my ear to the mast I can hear the wires tinkling against the mast. I think something has broken loose. It sounds as if there are some wires swinging in the mast.
Unfortunately, in this case, the PO built a box around the mast in the cabin to house an a/c tube to blow air into the vee berth. It's going to be a bit of a job as it's screwed and glued.
Thanks for the information on this topic. I had logged on to ask the same question myself -and there it was! :)
I didn't know about the inspection spot so I guess I'll pull the box apart first. I really don't want to have to pull the mast out.
Robert and Louise
Breezly
Catalina 36 MkII
2000 Hull number 1864
http://www.sailblogs.com/member/breezly/
