Hey BBQ experts!
blair's picture
blair
Hey BBQ experts!
I have BBQ, and have used it once, and then put it away.
Do most people keep it mounted all the time?
Where is the optimum place to have it mounted on a MKII?
Blair White
2004 C36 MKII # 2169 "Dash"
Pacific Beach, CA
Wavelength's picture
Wavelength
Best place is the aft rail. I prefer the port quater as I am right handed. I leave it there for the summer as it makes for quick access.
It is good to have a small shelf or some thing to put plates on.... it is too essy for a juicy steak to slide off the plate you hold in your hand. ?.. yes......do not ask.....good thing my freinds had an extra.
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
ProfDruhot's picture
ProfDruhot
Yep, that's the same place where I installed mine - port aft; very handy indeed. I picked up a little shelf like Ross alluded to, made from starboard material. It was in a stack of sale items at Tiffany's, er, I mean, WM, for only $28.
A project that ultimately turned in to somewhat of a major hassle earlier this Spring was adding a "tee" fitting and running a separate gas line back to the grill from the tank onboard. Of course, like most other projects onboard, it took twice as long to do it and 3 times the amount of what I thought I was going to spend. The result, I must say, is it is very convenient and I don't go through those gas canisters like I used to.
blair's picture
blair
You guys have any pics of your set up?
Blair White
Pacific Beach, CA
dpower
We keep ours on the starboard quarter rail because our dinghy motor lift is on the other side. We had a canvass cover that matches our sunbrella made for it and leave the grill on all the time except for the summer when it is put away. No sailing in the Florida summer heat and humidity for us.
David S. Power
Two If By Sea #1687
Burnt Store Marina
