Need to replace the o-rings on the stainless steel deck fill fittings for water (3 of them), diesel and waste. Don't have the right size at West Marine. Just talked to Catalina Direct and they don't carry them and had no information. This is for a 1999 MkII. The deck fills have slots that look like "dog bones."
Can I be the first guy on the planet whose o-rings have dried/cracked from oxidation over the years?! Searched the Forum here with no luck.
Any help appreciated!
Joe & Patti Worth
"Tehani"
1999 C36 MKII #1810
Joe, take one with you to ACE Hardware. Most of those stores have a great selection of O rings.
You could also call Catalina Yachts. Not sure if Dani Montessaro is still there but she has gotten me several odd little pieces for the boat. I needed two deck fill units, diesel and water, and they had them with correct labelling. I have the black ones with the raised piece running across the top, sounds like a different unit than yours, see attached picture (PS - ignore filthy boat that was what it looked like when we bought it and it just arrived on the truck). Catalina might have the o-rings if you've got an OEM deck fill.
I have the older black plastic caps on Caprice. Found "O" ring at Ace Hardware. I painted the fuel cap yellow to remind me that it is the fuel filler not the waste pump out which is right next to it so I don't put fuel into the waste holding tank.
