tool box
the cure's picture
the cure
tool box
Hi,would need to know how to get the tool box with the tool for removing the cutlass bearing for my Catalina 36 1988? and also the sucket for the bolts of the keel...
Thanks in advance for your help
Bryan Harvey
Catalina 36 wing keel
hull # 823
The Cure,
It's a link from the home page:
[URL]http://www.c36ia.com/node/23[/URL]
the cure's picture
the cure
Thanks Tom very much for your reply!!the link that you post me his no good.Could you be kind enough to try to look for the good one or just tell me how can i get the tool box.
Best Regards
Bryan Harvey
Bryan Harvey
hull # 823
The link Tom posted works as it should when I try it, there is a hyperlink at the bottom of that page to get to the form you need to fill out to get a tool.
Here is a direct link to the form:
[URL]http://www.c36ia.com/node/1006[/URL]
Hope this helps.
Bryan,
I should have pointed out that only members of C36/375IA are allowed to borrow tools from the tool box. Non-members will get some sort of error message when trying to access that page. Sorry.
the cure's picture
the cure
Tom,
thanks for your reply...the first thing I did is to email my membership,so waithing for the reply!!!know i will be a full catalina members with a long list of questions and years of learning and projects..
Best regards to you Tom
Bryan Harvey
Bryan Harvey
hull # 823
