We just spent our first day aboard soon-to-be-renamed Tehani (1999 Catalina 36 MKII #1810) in Maryland. Fun! But of course, we found or noticed a few things that we didn't pre-purchase. This is totally normal and none are significant enough to give us one ounce of regret.
1 - There is what looks like a non-repairable stain in the Formica laminate covering the nav station. We are figuring out our options to replace the laminate, but, as with all things, it ain't easy! Requires removing and replacing the nice teak trim piece on the nose of the opening part of the table. And if we can't match to the laminate surrounding the opening piece, we'd have to replace all of it!
2 - The "entertainment center" on the starboard forward side of the salon is missing its sliding tambour door. (We knew this one prior to purchase!) We are working on sources and quotes.
It occurred to us - to my wife actually; smart girl! - that there may be C36 MKIIs out there that were totalled in Sandy from which we might be able to salvage these parts at reasonable prices. Does this make sense?
If so:
[LIST]
[*]Do you know of any totalled C36 MKIIs?
[*]How would we get the word out about this to surveyors? To insurance companies?
[*]Any other ideas?
[/LIST]
Many thanks!
Joe & Patti Worth
"Tehani"
1999 C36 MKII #1810
Just a thought on that sliding entertainment door, I believe it was originally designed to house an old style CRT Television. Its the same on late model MKI's as well. Its not, in some opinions, the best way to use that space and there is at least one project article on here somewhere that describes a beautiful conversion of that space to a nice stroage cabinet.
I've thought of doing just that with mine, as I will never want to have a CRT TV on board.
Sam
Capt. Sam Murphy
1994 Catalina 36, Hull 1327
Shoal draft, two cabin model.
Panama City, Florida
Exactly, Sam. That cabinet was designed to house a fat CRT TV set, and I am sure there must be much better uses for it. As mentioned, there is at least one redesign in articles in the Technical - Upgrade library, but maybe this thread can be a trigger that causes our Owners creative juices to flow. Any ideas out there? Maybe you can describe in words, or attach a scan of a sketch.
After Katrina boats started showing up on eBay and similar online auction places. That will likely happen again so you might want to keep an eye out there.
Welcome to the forum. You might want to consider making an auto signature, it helps folks here provide information more specific to your exact boat. Click the UserCP link, then Edit Signature.
If you are a member you could post a "wanted" in our classified items for sale area. Any member who has upgraded to the cabinet configuration would probably like to sell their sliding door.
Stephen Kruse
Kruse Control #1428
1995 C-36 MKII SR/WK
Lake Lanier, Ga.
Jworth3,
My sliding door "bit the dust" (turned into multiple sliding doors) and I ended up ordering a replacement through Catalina. I sent them measurements and the new one fit perfectly.
Kent is the contact you want when you call/email in.
I am sure there are other options out there.
On a side note, with the help of a fellow C36 Owner, I pulled the CRT TV out and installed a 19inch Flat/DVD Combo unit on a mounting arm. The TV size limitation is the size of the opening for the cabinet opening and the "lip" that is infront of the cabinet, so pull dimensions. The arm is attached to the bulkhead. The TV is secured via bungee to the support rod that runs through the cabinet on the MKII. The door can be closed to hide the tv when not in use.
Jack
Solstice
Hull #1598
Lake Texoma
www.texomasailing.org
[QUOTE=jmontani;15800]Jworth3,
On a side note, with the help of a fellow C36 Owner, I pulled the CRT TV out and installed a 19inch Flat/DVD Combo unit on a mounting arm. The TV size limitation is the size of the opening for the cabinet opening and the "lip" that is infront of the cabinet, so pull dimensions. The arm is attached to the bulkhead. The TV is secured via bungee to the support rod that runs through the cabinet on the MKII. The door can be closed to hide the tv when not in use.[/QUOTE]
I have the same arrangement with a 17" LCD and folding arm, TV folds against bulkhead leaving all kinds of room in the cabinet for storage. TV folds out to face of cabinet opening when in use. (We also have a small dvd player in the cabinet, as we don't do 'tv' shows when cruising, but enjoy a movie on rainy days...)
I could not figure out how to make the old TV-cabinet into a better-utilized space.
I gave up on trying to figure someway to replace just the sliding cabinet door with something more useful. I gave up and just replaced the whole cabinet. I was inspired by John Lively’s article featured in this site last year. Lacking his skills and patience I just wanted to make cabinet doors that would “seamlessly” match the rest of the existing interior.
The challenge for me was to wanting to make the louver doors. I finally found an excellent design for a jig for making louvered doors from an old episode of the Old Yankee Workshop. Almost spent as much time making the jig as the actual doors.
Being a cheap SOB I used white oak and stained it to match the rest of interior. I would have had a fit making mistakes in hard to get and expensive teak. Filled in the track. Laid over an iron-on laminate. Moved the base of the chain plate rod outboard a few inches to clear the door frame.
Anyways I still have to the sliding door and the rest of the cabinet. You can have the sliding door for the cost of shipping. Or I can drop it off personally next October when my wife and I are taking our C36 to the Bahamas.
As for a TV, I am contemplating getting a pico projector to watch movies. The prices have come down on them and the specifications are getting fairly good.
[IMG]http://vermontsailor.net/Sail/New_cabinent_closed.jpg[/IMG]
[IMG]http://vermontsailor/Sail/New_cabinent_open.jpg[/IMG]
Nile Schneider
Mañana C36 #1798
Lake Champlain, VT
Looks very nice, Nile!
I too have an LCD TV in there on an arm. I swivel it back inside when not in use and bungee it to the tie rod for the forward lower shroud which holds it in place. Also have an inverter to power the TV and DVD player on the bulkhead.
My tambour door split into multiple pieces. I removed it by backing out the screws in the cabinet top. I took the pieces home and glued a piece of canvas-like cloth onto the back; it's now good as new.
One day I may redo the whole thing, but for now, it works fine as is.
Nile really did a nice job on that cabinet. I wish there was a turn-key solution I could buy to replace mine. When I purchased the boat one of the first things I did was throw out the TV and DVD that was in the cabinet. I go sailing to get away from it all. TV seems like more of "it all".
I did a great deal of custom teak work in my Catalina 25 ([URL="http://webpages.charter.net/compassrose/1989Catalina25.pdf"]http://webpages.charter.net/compassrose/1989Catalina25.pdf[/URL]) but these days I have neither the time nor motivation to go through that again. The fact that my boat is 2 hours away instead of parked in the driveway is part of the problem. Having the table saw parked under a bunch of junk doesn't help either.
If there were enough people looking to purchase a turn-key replacement for that cabinet, maybe someone will build a few for us.
Greg Jackson
SV Jacqui Marie
2004 C36, MKII
tall rig, wing keel,
VermontSailor -
How nice and generous of you to offer your door. We'd love to take you up on your offer. Please email me at jworth(at)mba1979(dot)hbs(dot)edu with your mailing address and the weight of the door (plus packing) and I'll send you the postage.
Oh, and I changed my signature!
Joe & Patti Worth
"Tehani"
1999 C36 MKII #1810
When I bought my boat it was missing two louvered doors. I contacted H&L Marine Woodwork in Compton California. (323) 636-1718 They apparently made a lot of the earlier Catalina woodwork when Catalina was in California. They sent me some forms for dimensions which they used to make the doors. The price was reasonable and they were a perfect fit. I finished them myself to match my cabinets. Worth a call.
Paul Meyers
1986 Catalina 36
Hull #615
Ventura, California
I tried H&L. After two phone calls asking for a quote on the tambour door, I never heard a word back. Guess they didn't need the business.
Thanks again to Nile for his door! This is my first interaction as a new member of the C36 community, and it couldn't be better. It's hard to part with our beautiful old C34, but you guys are easing the pain!
Joe & Patti Worth
"Tehani"
1999 C36 MKII #1810
I see that you're in Atlantic Highlands; How did you weather the storm (Sandy)? I've seen some of the pictures and I guess you're lucky to still have a boat. My family has a house in Cape May Point and we were holding our breath to see where landfall was going to be. We live in Turnersville and were lucky enough to only have a 30 second power outage.
We left our C34 on her mooring in Atlantic Highlands, with two regular 1" Polydyne mooring pendants (with extra sailcloth chafe gear) and a backup 1 1/4" 3-strand nylon storm pennant (with chain over anchor rollers). She rode out Sandy tight and dry; only damage was broken teak of anchor spit due to downward pressure of pendants. 15 boats started the storm on moorings. 6 were left after.
Most boats hauled out into the Municipal Harbor parking lot (our usual winter storage). There was 5' of storm surge in the lot with 5'+ waves. 80% of boats there were damaged; half of those totaled. All docks and equipment destroyed. All buildings but one destroyed or condemned. Looked like a bomb was dropped.
They hired a salvage company to pick up the boats and put them on stands. No water or electric power all winter. Harbor promises too be back in operation April 1st. We hope but we'll see!
Joe & Patti Worth
"Tehani"
1999 C36 MKII #1810
Nile- Very nicely done on the cabinet rework.... Looks like the way to go.
For those of you looking for the laminate on the shelf in the cabinet or nav table, it should be available from Home Depot, Lowes or a local counter top shop (cabinet shop specializing in kitchen/bath work should be able to point you in the right direction)... Made by Formica and/or Wilsonart.
Same cabinet shop should also be able to provide the tambour door if you want to stay with that look, they have several different options for material.
Anyone who can't locate either the laminate or tambour could contact me, my brother has a cabinet shop and can provide the materials.
Mark Kozy
"COLDWATER"
1999 C36 MK2 #1742 FK/M35B
Many thanks to all for your VERY effective assistance!
Joe & Patti Worth
"Tehani"
1999 C36 MKII #1810
I used Band-it Melamine facing, 24”x96” iron on sheets that can be purchased on-line at
[url]http://www.opentip.com/index.php?cPath=&keywords=melamine+band-it[/url]
for $31.51. They also sell a Band-It Edge Trimmer ($10.10) which makes it very easy to trim the front edge flush after ironing the Melamine facing on over the old laminate. The track slot was filled with auto body filler. The Melamine can be cut with scissors.
I have used this stuff for facing 1/2" MDO used on a number of drawer projects.
Nile Schneider
Mañana C36 #1798
Lake Champlain, VT
