Going up The Mast
blair's picture
blair
Going up The Mast
I've had the boat almost two weeks now, so I guess it is that time.
I'm going to do a little exploring, cleaning, and maintenance.
I have a couple of halyards that don't appear to be doing anything, so I guess I will use one to them.
My Plan is to use the block and tackle set up that I have for my tabernacle mast. I am going to attach this to the halyard, raise it up, and tie the halyard off.
I will then self winch myself up with the block and tackle.
I weigh 165 pounds, and pretty sure the halyard can handle that much weight.
Any input on my plan?
Blair White
2004 C36 MKII # 2169 "Dash"
Pacific Beach, CA
neilroach
Don't use the hardware, tie the block to the halyard. Use a second halyard to safty the first one. In good condition the halyards will hold a lot more than 165 lbs.
Pretty good idea to have someone on deck for safety and to send up forgotten tools and supplies.
Neil Roach
"Crewless"
1992 36, Mark I
Hull # 1174
Seattle
blair's picture
blair
Neil,
Good idea on using second halyard. When I had boat surveyed, the rigger just went up on one.
What hardware are you referring too?
Blair White
Pacific Beach, CA
Blair,
Now I am as confused as when you first mentioned lowing your mast when we did not know you had a tabernacle system.
I hate going up the mast, can not get any work done when I am up there as I am hanging on too tight. Going aloft does have its dangers, your mast will come down to you, why not lower it to look at your halyards?
Steve
I hate going up the mast and avoid it whenever possible. However, when I go up, there are a couple things I do for safety.
Clip my bosun's chair on to the main halyard and tape the shackle closed. A sailor was killed at a nearby marina when his shackle opened and he fell to the deck. Enough warning for me.
I tie off a 2nd halyard (spinnaker or jib) to the base of the mast. I have a piece of line about a foot long tied to the bosuns chair. I attach that line to the 2nd halyard with a rolling hitch, that can be slid along the spinnaker halyard as I go up. If the main halyard comes off the winch or otherwise lets go, I'll fetch up on the 2nd line.
I think my wife enjoys winching my butt up the mast even less than I enjoy being hauled up:D
blair's picture
blair
Steve, Gary
I have been told the mast will lower all the way to the deck, but I really don't want to drop it that far. I would need to remove dodger to attempt this. I don't want to put that kind of load on the lowering system either.
I would also need enough dock to be able to do this, which I don't have.
I am a technical rock climber and feel very comfortable in a harness, and aloft. If my block and tackle set up for the tabernacle is not long enough to allow me to get up there, I will just haul up an old climbing rope and climb it with mechanical ascenders.
Blair White
Pacific Beach, CA
Blair,
If you are comfortable up there, great. I did not understand the limitations you had in lowering the mast far enough to get to the mast head.
If you are a technical climber, I have several tasks due at the top of may mast due, halyard sheaves along with a bent windex that a bird flew into and bent sacrificing a wing he left on deck. If you find yourself in the Bay Area the beer is in me if you want to go aloft on my boat.
I am getting better with heights, just wrapping up painting my house, three story, lots of work at the top of a twenty foot extension ladder, but I don't like it.
