Fridge frustration
16 posts / 0 new
greigwill
Fridge frustration
My A-B refer was shutting off all by itself..for no apparent reason...voltage and batteries up...so i ordered a new thermostat,installed it...its still happening..it will run fine for 5 days,then just stop. When i jiggle the contacts on the compressor its seems to kick in again..sometimes it kicks in when i move the thermostat dial...i have tried cleaning the contacts on the AB unit..access very difficult but i have retightend all the terminals ..Anyone have any ideas?
Gibsons Harbour BC
www.landsendbc.ca
Is the fan still working?
Have you removed and either cleaned or replaced the fuse on the module?
Have you removed, cleaned and replaced the connections on the module?
Have you checked the connections at the fuse in the electrical panel?
Have you checked the voltage at unit when it shuts off?
A good reference is Richard Kollman. [url]http://www.kollmann-marine.com/[/url]
Good luck.
greigwill
Stu,the fan is working fine,i didnt know there was a fuse somewhere else besides the breaker panel...not sure what you mean by 'the module',is that where the wires come into the compressor/condenser unit..i will check voltage at the unit when it shuts off tomorrow thanks.
Gibsons Harbour BC
www.landsendbc.ca
[QUOTE=greigwill;13794]... didnt know there was a fuse somewhere else besides the breaker panel...not sure what you mean by 'the module',is that where the wires come into the compressor/condenser unit..[/QUOTE]
Yes, there is a fuse right where the wires attach, the "black box" is called the electronic "module." It's a 10A fuse. For some reason, Catalina used 15A fuses at the electrical panel on our boats. Most of us have switched those to 10A fuses (those of us with older boats, that is :)).
Capt. Sam's picture
Capt. Sam
I recently had a simular issue with my 19 year old A-B. It would run fine for a day, then the compressor would stop, with the fan cycling on and off.
If you do a search you should find several threads on the issue that seems to be common. I tried everything that the AB tech support suggested and everything I found in the other threads but I couldn't fix it. The problem still occurred when I wired the unit directly to a well charged battery sitting in the cockpit. So rather than call in a service person to the boat, that would have cost a minimum of $140 (1st hr) plus a likely $210 for freon, or buy a new controller in the hopes that that was the issue, I pulled the whole thing out and am now installing a SeaFrost system with two SS evaporator plates that should be more efficient and increase my freezer space.
Good luck.
Sam
Capt. Sam Murphy
1994 Catalina 36, Hull 1327
Shoal draft, two cabin model.
Panama City, Florida
greigwill
Thats what i was afraid of CapSam..i see Defender sells the module for $400 and the whole compressor unit for $800..deep sigh...
Gibsons Harbour BC
www.landsendbc.ca
In my earlier reply here, I provided a link to Richard Kollman. He sells electronic modules for all of $150!!! It's a great buy. Have a professional check your "freon" level first, look around Richard's website and then decide.
greigwill
Stu,i cant find modules on the Kollman site,only books and lots of good advice.I sent him an email about this,do you have another source?thanks Greig
Gibsons Harbour BC
www.landsendbc.ca
greigwill
Stu,ignore my previous post..Dick Kollman just replied with a detailed email..yes he still sells these units..plus he offers cheap testing of my existing unit..will post my results thru this process after i follow more of his testing guidelines.thanks for your help and the link,Greig
Gibsons Harbour BC
www.landsendbc.ca
Super, looking forward to your resolution(s).
Would you consider sharing your emails with Dick here?
greigwill
Stu,no problem,i am out the door for a 7 day Gulf islands/Victoria trip..(with ice in my fridge)when i get back i will figure out how to post his emails..cheers
Gibsons Harbour BC
www.landsendbc.ca
greigwill
Just an update..while cruising the gulf islands last week,the fridge quit again.Taking the advice i received in hand,i managed to remove and clean the pos/neg wires into the module,figured out how to remove the fuse cover and fuse(which was corroded)..it has run perfectly ever since.Out of curiosity,i timed the on/off cycles..approx 5 mins on...then 10 mins off,maintains +3C..so its running 20 mins of every hour..Is this a lot?I get 2 or so days without charging the batteries(4 golf cart 6 volts,new),then they are pretty low.
Stu,can i send you the emails from Dick directly?if you give me your email i will just forward them to you,you can then post them or whatever you like.
Gibsons Harbour BC
www.landsendbc.ca
greigwill
Stu,here are the emails from Dick Kollman..
"..Unless you have Superman's eyes checking voltage is of no value when looking for a low voltage micro spike. The module recognizes a spike and will terminate compressor start up, this is why test number 4 is important on older boats. As far as touching module and compressor stops have you cleaned module fuse contacts? What about cleaning and replacing plus and minus wire terminals at module?"
RLK
----- Original Message -----
To: [email]richard@kollmann-marine.com[/email]
Sent: Sunday, July 15, 2012 2:55 PM
Subject: RE: elect module
Thanks Dick,yes i have a 20 yr old AB fridge on my Catalina 36..It was shutting off on its own,so i bought and installed a new thermostat..its still doing it,runs fine for 4 days then for no reason,shuts off,then when i jiggle and tap the module it goes again,perhaps for another 4 days with no problem..i will test for voltage levels at the module after compressor shutdown but,as you say,perhaps this is of no value,regards,Greig
1. Place jumper wire across thermostat terminals, Compressor still does not run.
2. Disconnect black fan wire from electronic module. Compressor still does not run after fan ground wire is disconnected. One of the 10 transistors in this fan fails it can cause module to prevent compressor from running.
If Compressor runs after black wire disconnected replace fan.
3. Run correct size and correct polarity fused jumper wires direct from a fully charged battery to module in order to bypass all boat’s wiring. Volt meter readings are of no value at module. Now if compressor runs there is a bad electrical connection somewhere in boats wiring causing a low voltage spike during compressor startup.
Compressor still does not run electronic module needs to be tested on another unit.
I closed my shop but after seeing what is being charged by boat refrigeration companies who will test modules charging $50 and charging as high as $385 for new 4 pin modules, I decided to test and sell modules for a fraction of what is currently being charged.
If your shipping address is in the US I will test your module on my Danfoss compressor refrigeration test stand. This test stand will run at max compressor load for a one hour. I will then return your module to you for a shipping and handling charge of $20.
Four pin modules for BD2.5 and BD3 twelve volt compressors only:
New module non Danfoss $150 plus $15 insured shipping. Modules will only be shipped to addresses in the US.
Because your unit is old and if it needs a new electronic module there is a risk that something is wrong that caused module to fail so most companies will refuse warranty of these modules. This is my electronic module warranty:
If any used module I sell fails to operate your unit it can be returned within 30 days for a full refund.
Any new module I sell can be returned for full credit within 30 days. Because of my own risk involved for the next 11 months I will return only 50% of the new units purchase price if module is returned within the first year.
To have module tested or purchase a new four pin module send check to:
Richard Kollmann
2430 Sugarloaf LN
Ft. Lauderdale FL, 33312
Gibsons Harbour BC
www.landsendbc.ca
If it's an intermittent electrical issue, it must be a connection, somewhere.
Who woulda thunk?!? :)
Thanks for getting back to us.
greigwill
For future reference,if anyone has fridge or "module"issues,one of the things that held me from correcting this problem earlier was the really difficult access to the wires into the module..I really wasnt able to clean and correct the crust and corrosion until i realized that the module is only held onto the compressor unit by 4 screws! simply unscrew them and the whole module comes away with about a foot of slack on the wiring...very easy to service once its out in the open. Also i no longer put my wet mooring lines in this locker..this is now a dry locker only.
Gibsons Harbour BC
www.landsendbc.ca
