Deep Cleaning and How Much Bleach Can I Safely Inhale?
15 posts / 0 new
Channel Islander's picture
Channel Islander
Hi friends,
My new '84 C36 comes home on Wednesday and I want to give her a very thorough scrub and cleaning. The boat has light mold and moderate dirt throughout and I plan to take the cushions to be cleaned at a carpet cleaner, then take advantage of having her emptier than ever again to scrub-a-dub-dub. In particular I plan to scrub under the couches, the aft berth, any bilges I can reach, etc.
One instinct tells me to slather and scour the whole thing with bleach to really kill any mold and clean any gunk . . . another tells me that filling a below-water enclosed space with chlorine gas is probably not beneficial to my respiratory system. Any advice? If I put a huge fan on board and open all hatches will that provide enough airflow? Or should I rethink my cleaning agent?
Nick
Nick Tonkin
dejavu's picture
dejavu
Since you only mentioned "light" mold, I might try a general purpose cleaner first. Something like Simple Green, Amazing Rolloff or even a 409/Fantastik type cleaner would work. Some of the kitchen/bathroom cleaners have a disinfectant to help with the mold. After a onceover, go back and hit any stubborn mold with bleach. That's how I'd do it.
Nimue's picture
Nimue
I would do a light bleach/water mix in a spray bottle and have at it with the hatches open. I don't think you'll kill yourself - this is how we did it on our '83 boat when we brought it home full of mold and other stuff.
Try to do it uniformly as too much bleach will discolor the oiled teak.
On durable surfaces, a wipedown with a light bleach mix would be appropriate, I think.
You never want to mix bleach and bleach-based products with ammonia-based products, as the result is chlorine gas, which is a deadly gas. 'Not beneficial' to your respiratory system, nor to any other of your body's systems...if you agree that 'not beneficial' is a synonym for 'fatal'.
Here's a better idea...for bilges and other enclosed spaces, a spraydown with vinegar really does the job. First, wash with soapy water: I buy a synthetic mop from the grocery store, cut the handle to about 2 ft in length, then use a garden hose on a nozzle to wash the bilge with soapy fresh water, swabbing with my shortened mop, going after dirt and crud waaaayyyy up beneath the floorboards. Afterwards, using a garden sprayer, I spray vinegar throughout the bilge spaces. Plan to leave all bilge areas open for a week or so afterwards to let the vinegar evaporate. I wouldn't use a fan during this time, as you want to let the vinegar dissipate at its own speed. In a week or two the air will be pristine.
The overall effect of spraying vinegar is so powerful that no one but you will want to be on the boat for a couple weeks (in my own experience). That says a lot, though, because the result will be a pristine boat. Costco sells two gallons of vinegar for cheap, cheap. One gallon will do you for this task, and the other, with olive oil, will yield anough salad dressing for the next 10 years.
[BTW, make sure you have replaced the black rubber hoses used in the sewage system. These are notorious for developing microscopic weeping which you can't see or even feel, but which are the source of awful nuisance odor on most boats.]
Well I typed a reply to this post earlier today but it did not show up.
I used half a cup of chlorine bleach per gallon mixed with some dish soap for a purification on my boat when purchased. Larry is correct you DO NOT want to mix amonia or acid based cleaners with chlorine bleach as it creates chlorimine gas, not so good for cleaning but, a good choice if you have rats, termites or a spouse that you do not want.
Don Casey suggested in his book This Old Boat using a bleach solution wash down to get rid of mold and mildew aboard, he also suggested using it on the woodwork and using Lemon Oil afterwards to rejuvenate the wood and it also prevents mold from reoccurring . I did this on my boat as it had had and exhaust leak prior to my puchasing her that left soot everywhere. A good scrub down with the soapy bleach solution and treating the wood made her sparkle. I did this right after purchasing her as you are doing with your boat,
it was a great bondiing period and gave me the oportunity to learn a great deal about the boat by opening and cleaning every accessable spot.
manonash's picture
manonash
I hate the smell of vinegar almost as much as I hate the smell of bleach. (Though, I did find a "lavender" scent bleach recently that we use in the head that doesn't bother me at all...)
Try mixing a little Oxiclean (yes, the stuff you mix when doing the laundry) with Murphy's Oil (soap). It kind of turns into a thin "snot" for lack of a better term. That might sound pretty odd, but I learned it from a funny old guy in my Lake Michigan days and it works great!
My first boat was a '75 C-30 (Hull 101, if I remember correctly) that has been left closed up for three years after the owner had died, etc... I spent an afternoon wiping everything down and it cleaned up nicely. Four years later, I sold the boat and never say any mold/mildew again...
Good luck!
__________________
Steve Ramsey - Puget Sound
Balsamic vinegar smells much better especially mixed with garlic and olive oil, not so good for cleaning and a bit more exspensive at Costco but worth it. Larry's taste is just not that sophisticated.
[QUOTE=Nimue;10620]I would do a light bleach/water mix in a spray bottle and have at it with the hatches open. I don't think you'll kill yourself - this is how we did it on our '83 boat when we brought it home full of mold and other stuff.
Try to do it uniformly as too much bleach will discolor the oiled teak.[/QUOTE]
Be VERY careful when spraying bleach in any location where it might drip or overspray onto the teak. It WILL discolor it. (Don't ask me how I know).
By the way, if anyone has suggestions for restoring the color in teak that has been accidentally bleached, I'm all ears!
[QUOTE=Nick_Tonkin;10618]Hi friends,
... I plan to take the cushions to be cleaned at a carpet cleaner...
Nick[/QUOTE]
We considered doing that after we bought our boat last year. But it turned out to be much easier (and considerably cheaper) to just remove the covers and run them through our washing machine on gentle, cold water wash using Woolite. They came out clean and nice smelling.
Channel Islander
I just took all the covers off I could, but the seat backs are upholstered and would need to have the buttons refitted if I took the covers off.
Did you do that, so you could machine-wash the seat back covers? I was going to rent a machine and do those here on the dock.
Thanks, Nick
Nick Tonkin
Channel Islander
Thanks Larry. I will try this tomorrow. Really want the bilge under the aft berth where my young son will be sleeping to be free of mold as much as possible.
Nick Tonkin
Channel Islander
Hmm, guess all the replies go on the bottom, sorry for overposting.
I just wanted to thank everyone for their advice and suggestions. In the end I hired one of the local cleaning wenches who does this for a living and already has all the supplies. I will be aboard scrubbing the bilge and so on so I figure I'll be able to get to know the boat pretty well . . . but I just know Cindy will get it cleaner than I would!
Plus she agreed to give me great deal if I promised to take her and her friends sailing! How could I refuse :)
Thanks, Nick
Nick Tonkin
Sounds like a good solution. Post pics of your crew.
[QUOTE=Nick_Tonkin;10651]I just took all the covers off I could, but the seat backs are upholstered and would need to have the buttons refitted if I took the covers off.
Thanks, Nick[/QUOTE]
We didn't have that problem (i.e., the upholstored backs with buttons); obviously, the originals were replaced at some point by a prior owner.
Channel Islander
Yep, they have been replaced I guess. The two sitting areas have a smoother material; the berths have a velvety material that is comfy but obviously not durable as one has a wear hole and I tore a small hole in another getting the cushion back in. Bummer. They are from Huntington Beach according to the label so it's within 100 miles . . .
All in all getting the covers back on was a RPITA and the ones I cleaned with the rental Rug Doctor machine cleaned up nicely, might recommend doing them all that way unless you fancy a good couple of hours of writhing around the dock wrestling the cushions and looking like you're losing . . .
Sure are a lot of cushions and drawers on that boat!!
Nick Tonkin
