Heat Exchanger Maintenance
RPowers's picture
RPowers
Hello,
I finally had a chance to do some maintenance today.
Did a complete oil change/new oil filter (after 80 hrs).
Changed the belt to new.
Changed the raw water impeller to new (was 2 years old, still looked great).
Got to the heat exchanger. Changed the pencil anode. The old one was almost gone (!). New one fit in great.
I have new end caps and gaskets for the heat exchanger, but held off pending advice from you experts.
Q: What is the best way to clean the inside passages? It seems like a challenge to get a poker or long brush inside the tubes because the side entrances have limited access (Universal 35). Any advice?
Btw, the engine runs cool enough, maybe I don't need to do anything.
Captain Rick Powers
(USCG OUPV)
1999 Catalina 36 mk II
Hull#1745
Std Rig, Fin Keel
Palo Alto, California
San Francisco Bay
baysailor2000's picture
baysailor2000
As they say - do not fix it if it is not broken. I would leave it alone.
Coyote Point, San Mateo, CA.
Sounds like your all set. Sometimes just takeing the ends off you can some of the anode (zinc) should it have crumbled. A wire through each tube to make sure there is no obstruction. Best way to clean the HE is to take it to a radiator shop and have them service it. Only need to do that if you are experiencing a problem.
The best way to service the HX is to completely remove it from the engine.
