Belt replacement Raymarine MkII wheel drive
The wheel drive on my Raymarine (autohelm) S1 autopilot started acting up 2 days ago. This is the grey 'MkII' drive unit. I'd spilled some water on it, so figured it was just slipping. Yesterday, I adjusted the clutch so the belt was tighter (in fact too tight), but no improvement.
The drive lets out a nasty noise; at first I thought that was just the belt slipping, but now I'm not so sure. With the drive locked, and the pilot on standby, I can turn the wheel slowly and hear the motor turning, but then it 'skips'. If I keep turning, it skips again. This makes me think there's something wrong with the motor drive wheel, or perhaps multiple 'teeth' missing from the belt.
Has anyone disassembled the wheel drive? I'd like to disassemble it and take a look, but nothing in the manual tells you how to do it. I had my old black drives apart enough times to do it in my sleep, but haven't yet had the pleasure on the new ones.
I vow to get a below decks pilot. I have had more trouble with these danged wheel drives than I care to relate, they just don't seem to stand up to a C36 (though I had plenty of trouble with the black drive on my C30, too).
I'm on the boat single handed, with an all day sail/motor to get back and don't feel like steering the whole way. Any help would be appreciated.
Ken Juul's picture
Ken Juul
I'd give the wheel drive unit a good washdown with fresh water before you open it up. The manual says they should be cleaned after each use, but monthly is probably sufficient. Direct the water into the slot just above the motor and turn the wheel chock to chock a couple times.
Ken and Vicki Juul
SV Luna Loca
C34 #1090
Brought the drive home and disassembled it. Turns out the gear drive unit is stripped, as I'd suspected. The belt and toothed drive wheel, clutch and it's adjustment are all fine. With the motor and belt removed, if I turn the toothed drive wheel (difficult), it turns a bit, then hits a spot where it just spins, with a grinding noise. I can't for the life of me navigate Raymarine's website to find the part, so I guess I'll have to return it for the flat rate repair ($275).
Looks like I'm going to have to budget for a below deck pilot for next season. This pilot is rated to 16,500 lbs displacement and I'd guess I'm pushing that or more.
